Thread: 1.9 CDTI (150) intermittant start
    Apr 2012
    dunstable
    Default 1.9 CDTI (150) intermittant start
    wondering if any electrical guys can shed some light for me.
    Vectra 55 plate 1.9 (150).
    my main problem is that twice now it has failed to start (wont even crank over) after stopping, battery seems healthy more than healthy enough.
    No fault codes, no fault lights.
    all other electricals work fine.
    turned key on and off a fair few times and it appears to work.
    basically its like a wire has come off the stater motor, havent had a chance to look yet as its raining (again).
    is there common problems with the CIM module that would cause these symtoms?
    cheers guys
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Could be a faulty ECU.
    Do all the dash lights come on as they should ie: engine management light, does this come on as it should ?
    The reason I ask is if it don't come on its a communication fault to the ECU and the car wont start.
    Apr 2012
    dunstable
    cheers mate, yeh reading through the forum that seams to be what it points to. eml light stayed off.
    still only happened twice since ive had the car ( probs turned the ignition about 500 times since i brought it) ill keep an eye and keep posted if it keeps on going.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    May be a broken wiring harness, the CDTI's do suffer them - not one of the common faults but there have been a few suffered this. I would have the electrics checked before parting with £800+ for a new ECU.
    Apr 2012
    dunstable
    Any idea where to check for breaks in the loom? im just keeping an eye out for now (would be a used ecu, tech 2 jobby anyway, i dont have a money tree,or even a garden for one at the moment lol.)
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Check down the back of the engine near the steering pump area. Check the connections to the steering pump (I believe this is main connection between ECU and the rest of the car). Check near the front drivers wheel arch too. The ECU sits in a cradle infront of the drivers wheel arch. Check connections to this are firm.
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Mine did the same and it was the stater motor that went....
    Try getting a garage to have a look, should cost no more than £120.
    Quote Originally Posted by joe.t View Post
    cheers guys
    May 2011
    South London
    ECU 's can be bought for around £200.00
    Don't be frightened by anyone telling you its a @ £1000.00 fitted for one.
    See this thread > http://www.vectra-c.com/forum/showthread.php?t=158135
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by C-Owner View Post
    ECU 's can be bought for @ £100.00
    Or don't be frightened by someone telling you the ECU is goosed in the first place.
  1. Cdti 150 non start!!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 15th April 2012, 16:27
  2. Vetra cdti 120 won't start from key
    By kirkyoke in forum Engine & Drivetrain
    Last Post: 12th March 2012, 00:11
  3. CDTI 120Non Start
    By stevemechanic in forum Engine & Drivetrain
    Last Post: 9th August 2011, 21:30
  4. cdti smoke on start up
    By hitcho in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 10:14
  5. 3.0 CDTI fails to start
    By Dominic Brown in forum Engine & Drivetrain
    Last Post: 4th September 2008, 22:11
