Thread: Intermittent high fuel consumption
    Dec 2010
    Dorset
    Default Intermittent high fuel consumption
    Apologies of this has been covered elsewhere but having done a search I cannot find anything that specifically covers this issue.
    1.9CDTI 150, 2007. Generally does 42-44mpg on the sort of roads I use for a daily commute rising to 46-48 on motorways. With the instaneous fuel consumption readout selected at idle it shows 0.2-04gal/hr depending upon how warm the engine is and whether the climate control is on.
    Occasionally - not normally more than once per tank of fuel and more often than not only once every 203 tanks of fuel, the instantaenous fuel consumption on the run will suddenly drop by at least 50%, the distance to run will count down 1 mile every 200 yards or so travelled and if I pull up to a halt the instantaneous readout at idle shows 1.1gal/hr. If I switch the engine off for 10 seconds and restart, the problem clears. The dealer has checked for fault codes and there are none.
    Very occasionally (3 times in past 6 months - I've had the car for 3 years) it does it repeatedly. So for example a month or so back I was driving up the M3 to London and had to pull over every 2-3 miles to switch off and restart. After doing this about 10 times I gave up and accepted that I would have an average of about 20mpg, but about another 10 miles further on it cleared completely; the drive back was fine and I got it up to over 50mpg average.
    When it's doing it the performance doesn't seem too bad although you can tell that it is over-fuelling from its slightly rough running. Since it is intermittent and there are no fault codes, the dealer (whom actually is very good normally) hasn't got any suggestions. So I wonder if the collective knowledge here can help?
    Many thanks
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    An estate by anychance?
    DPF doing a regen
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Its called a DPF regeneration worst thing you can do is switch it off then on again let it do its thing its quite normal
    PRESTON
    If this car has a DPF, DO NOT SWITCH IT OFF. Sounds like it is doing a regen, let it continue and drive above 50, if it is safe to do so, for about ten mins. This will allow the regen to complete successfully, the mpg will return to normal and it probably wont do it for another 700 miles. By switching off, you are resetting the regen and after a few failed attempts, it won't attempt another, which will cause you big problems.
    Regular Member John Bishop's Avatar
    Oct 2010
    Quote Originally Posted by barney490 View Post
    After 3 unsuccessful attempts it wont try it again apparently
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I normally take my car for a little sprint down the M1 for a junction or two, in 5th and 70 mph.
    The frequency of the regens is govered by how you drive really, give it loads of beans and there will be loads more soot in the exhaust causing more regens, drive at 70 on the motorway and it will be a while inbetween regens.
    Dec 2010
    Dorset
    Thank you all for your prompt responses
  1. Replies: 1
    Last Post: 22nd October 2012, 07:55
  2. why the high fuel consumption?????
    By richje100 in forum Engine & Drivetrain
    Last Post: 27th March 2011, 20:28
  3. high oil consumption
    By bombai in forum Engine & Drivetrain
    Last Post: 15th February 2011, 23:14
  4. Fuel Consumption seems high, Signum 2.0 Deisel
    By Mad_Matt in forum Engine & Drivetrain
    Last Post: 22nd February 2008, 19:14
  5. oil consumption too high???
    By Nickzx6r in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 21:19
