Thread: Heating Issues - CDTI 150
    Birmingham
    Default Heating Issues - CDTI 150
    Folks,
    My dad complained today that his CDTI 150 wasnt heating up properly, he said the blowers were on full heat and it was still puffing out cold air through the vents.
    Thermostat?
    Your thoughts please.
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    99% thermostat mate - whats the temp guage doing?
    Birmingham
    sat about half-way, although yesterday in traffic it was at 90+.
    Where is the stat located on this? Will it need changing or just a punch in the face?
    Bye bye Vec B
    - Hello Siggy!
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Vaux-Man-G View Post
    Hmm - if the car is heating up to temp and staying between 86 - 90 then maybe not the stat.
    Normally the stats fail open and therefore the cars temp doesnt warm on the temp guage
    Middlesex
    Trim : SRI
    Mileage : 100k
    If he changes the heat to cold - does it go very cold or does the cabin blower not change temp at all..
    Could be the mix flap motor / or the arm that connects the motor to the mix flap.. This is located behind the glovebox to the right on the side of the center console..
    Wonder if that isnt operating.
    Birmingham
    .....next diag? What am I looking for?
    Bye bye Vec B
    - Hello Siggy!
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Its the air control servo on the left side of the air box it can be seen when you take the glovebox out. It is a black motor with a red arm. Take out the glovebox get the temp up and then adjust the temp in the car and see if the red lever moves if it doesn't help it and do this a few times it generally fixes it. Well it worked for me about 18 months ago and its still going strong
    Have a read here:
    http://www.vectra-c.com/forum/showth...lovebox&page=2
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by paulhb View Post
    Have a read here:
    Thats the one
    Just changed mine when I put a new blower in as I had a broken cog so was getting a click click click when I turned to cold.
    Birmingham
    Hats off guys. You lot are good. Problem solved!!! Red thingy was stuck. Thank you.
    Bye bye Vec B
    - Hello Siggy!
    Middlesex
    Trim : SRI
    Mileage : 100k
  1. 1.9 cdti 150 eml & EGR & DPF issues
    By carvaletingpro in forum Diesel Engine related
    Last Post: 24th August 2012, 08:16
  2. 1.9 CDTI 150 - Issues
    By me9141 in forum Engine & Drivetrain
    Last Post: 27th April 2012, 17:56
  3. cdti 150 mpg issues
    By Kcs in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2011, 23:44
  4. Issues with CDTI 1.9 SRi 150
    By warren77 in forum Engine & Drivetrain
    Last Post: 14th May 2011, 12:12
  5. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
