Results 1 to 10 of 11
Thread: Exhaust Bore
    Regular Member scarydeath's Avatar
    Sep 2009
    County Durham
    Default Exhaust Bore
    Hi everyone,
    Got a replacement Exhaust fitted from Kwik Fit (Simply as they are convenient and way cheaper than the Dealers) but it sounds as if they have fitted an exhaust with an exit hole bigger than it should be (Sounds all boy racery, which may appeal to some of you but hey!).
    Will anyone on here be able to spot whether this is the correct exhaust for an 08 plate Vectra C Petrol 1.8 VVT, or have they fitted me the wrong back box?
    Thanks!
    May 2011
    Broxburn
    Hi there
    I work for Kwik Fit customer services team and spotted your comment on the forum.
    Thanks for posting a picture, but it's always difficult to diagnose this way. The best thing to do is return the vehicle to the centre and they'll take another look at it. Sorry, I know this is an inconvenience, but one of the team will be able to take a closer look.
    If you have any questions, please drop us an email at kwikfitwebcare@kwik-fit.com
    Kind regards
    Andy
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by KwikFit View Post
    Hi there
    Kind regards
    Andy
    You may have seen this but if not I would change your name even if your here to help
    General Rules of the Site
    1. Accounts
    Only one account per person is allowed i.e. one username. Any additional usernames registered by the same person will be deleted, the user sent a warning and their account temporarily suspended. Further violation of this rule will result in the member’s original account being suspended for an extended period.
    Please do not use trading names as your username unless prior permission has been given by Admin, any such usernames will be deleted or changed.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep what ziggy said the rules are clear follow them please
    South east
    Quote Originally Posted by scarydeath View Post
    Hi everyone,
    No doubt Kwik Fit were way cheaper than a Vauxhall dealer, but it's not a like for like product. The Vauxhall exhaust is double skinned, so when the outer layer rusts through, there's still another layer to go. The Kwik Fit one is single skinned - when it rusts through, you have to throw it away. Secondly, the Kwik Fit one is just a large tube with an oval profile, whereas the Vauxhall one is specially shaped for strength and to reduce drone.
    South east
    Hi there
    Well that was profound advice wasn't it? Is there a single, existing member of this forum that couldn't have given the same advice?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Actually thinkin about it you would of bin better goin to a local exhaust place as rebellion says cheaper because the quality is alot lower
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Quote Originally Posted by Rebellion View Post
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    The best thing to do is return the vehicle to the centre and they'll sell you new tyres, brakes and shock absorbers you don't actually need
    Fixed that for you.
    South east
    Quote Originally Posted by s_zigmond View Post
    1. Accounts
    It's also a username being shared by several Kwik Fit employees - there's an Andy using it, and also a Gerry, and probably several more.
  1. exhaust bore
    By chrosty in forum Diesel Engine related
    Last Post: 22nd January 2012, 12:56
  2. exhaust bore
    By gazturbo in forum Engine & Drivetrain
    Last Post: 3rd January 2012, 13:11
  3. exhaust bore size
    By craig1989 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2010, 09:27
  4. Exhaust Bore?
    By OPC in forum Diesel Engine related
    Last Post: 18th May 2010, 22:02
  5. Exhaust Bore
    By corsa_si in forum Tuning
    Last Post: 16th April 2009, 15:32
