Results 1 to 2 of 2
Thread: Auto box oil
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default Auto box oil
    Can i just confirm if the amount of oil is 3 or 7 litres for the vec auto gb, also has anybody followed this method before
    Important note
    Remove level plug.
    Fill transmission with specified amount until ATF drips from level tube.
    Fit level plug.
    Add 0,5 litre of ATF.
    Start engine.
    Select each gear for 2 seconds, then return selector lever to 'P', repeat twice.
    Connect diagnostic equipment to check ATF temperature.
    Ensure ATF temperature is 70-80°C.
    Remove level plug.
    Allow stream of oil to reduce to a drip.
    Fit level plug.
    Switch off engine.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
  1. auto wipers, can you fit auto headlights?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2011, 11:32
  2. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  3. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  4. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
  5. Vectra 1.9CDTI 150 Auto v 2.2Direct Auto
    By mattr in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:16
