Results 1 to 10 of 21
Thread: check safeguard
    Apr 2012
    manchester
    Vehicle : vectra sri cdti 120
    Trim : cdti/ sri
    Default check safeguard
    i have had a fault showing saying "check safeguard" because the alarm has been going off on it's own for no reason. the fault was the alarm siren box out of the boot , but if i bought a new one would it still be almost silent. because at the moment it is loud because it's switched to the cars horn
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    im getting this too ive just wrote it in my post called "diagnostic readout".
    dont know if its my alarm siren playing up
    im gonna check all plugs and fuses as advised
    Regular Member John Bishop's Avatar
    Oct 2010
    If it was an estate it could be the rear window sensors causing it. I had it on mine and it appears to be a fairly common problem with estates.
    Apr 2012
    manchester
    Trim : cdti/ sri
    the alarm box on my vectra was so quiet when it went off it's useless. but now the technician has toook the alarm siren box out , it is as loud as anything now because it uses the cars horn instead. i don't know if i want to put a new siren in for fear it will be just as quiet
    Apr 2012
    manchester
    Trim : cdti/ sri
    i think my problem aroused through my rear light cluster seal leaking water in
    Oct 2010
    Quote Originally Posted by rickh01 View Post
    They are all like that unfortunately. There is a How2 thread to change it to the horn without removing the sounder
    Apr 2012
    manchester
    Trim : cdti/ sri
    Quote Originally Posted by bishbang View Post
    if i put a second hand sounder in and did that. would it get rid of the "check safeguard" notification every time i started up. because now the sounder is out it's there all the time till i cancel it?
    Apr 2012
    manchester
    Trim : cdti/ sri
    how do i find the link, i'm new to this club i've only just joined, thanks
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    If you have estates - check this that I did:
    http://www.vectra-c.com/forum/showthread.php?t=161966
    If not its likely to be the ultrasonic sensors.. A good way to test this is before locking the car, press the button to disable the internal ultrasonic sensors then get out and lock the car.. Unlock and turn ign on, if you dont get the error then its the sensors.. Common, and often unplugging them, contact cleaner and plug back in fixes...
    HTH
    A
    Oct 2010
    Look on the How2 section or use the search facility at the top of the page. Not sure if putting a second hand one in would solve it, depends what the actual cause is.
  1. Safeguard Check.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 17:43
  2. Check Safeguard
    By Tam80 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 08:43
  3. Check Safeguard
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2011, 22:51
  4. Check Safeguard
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2010, 22:41
  5. Check Safeguard (Again)
    By stevem in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2008, 19:31
