Results 1 to 2 of 2
Thread: Quick question
    gwent
    Default Quick question
    Hi had fault code come up p2075 this has happen a couple of times in the last few times so done the swirl flap test with vaux com comes up with 5% before doing the test and when doing the test 95% is this ok or should it be 100% the swirl bar is on there is no oily or sooty mass around the swirl bar flaps was going to clean the egr and spray carb cleaner into the inlet manifold on the weekend to see if this helps as if i can get away from fitting a new inlet manfold till the summerthis is on 07 1.9 cdti 150 with 34k on the clock
    South east
    Have a read of this thread, it might give you some pointers. Also, your post would be much easier to read if you use full stops between sentences.
    http://www.vectra-c.com/forum/showthread.php?t=119615
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. DAB Box quick question
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2009, 01:25
  4. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  5. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
