Thread: Spanner light
    Aug 2010
    Derbyshire
    Default Spanner light
    Following on from this thread http://www.vectra-c.com/forum/showthread.php?t=162068 I was expecting everything to be solved. But I have a small problem now.
    When will the spanner light finally stop showing?
    So if you haven't read the thread a quick explaination.
    My horn stopped working so I removed the centre section of the wheel and airbag. Battery disconnected first and when I'd put it all back together everything is working fine. Even the horn seems to work better not needing a firm push like it did before.
    So the spanner light shows on start up when the car is left parked a few hours or overnight. If I start to drive with it on it goes out after say the first mile of driving. If I restart the car immediately the spanner light will go off and stay off, until the car is left again for a few hours, then it's on again.
    Will disconnecting the battery then reconnecting clear this for good or is there something else that can be done? BTW I must have started the car around thirty times now and I've read it will self clear after a few starts, but not so it seems.
    Any ideas what to try apart from the battery disconnect, reconnect?
    Mick
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Gonna take a guess here and say it's a diesel and it needs it's glow plugs changed
    Aug 2010
    Derbyshire
    Quote Originally Posted by John IS3 View Post
    It is a diesel, Signum 06 plate.
    Hmm....I see your thinking on this, but a coincidence I think that it only started showing the spanner light after I'd had the battery and airbag disconnected.
    Mick
    Regular Member bigalec's Avatar
    Feb 2012
    prestwick
    Trim : SRI 1.9 CDTI 16v
    Post
    Quote Originally Posted by MickAP View Post
    Mick
    I would say same it needs it's glow plugs changed i know coz mine does it too just not got round to fixing it yet lol
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
