Results 1 to 3 of 3
Thread: Turbo seals? 1.9 CDTi 120
    Regular Member R33Leroy's Avatar
    Mar 2012
    Canterbury
    Vehicle : Vectra C 1.9CDTI Energy Ltd Ed
    Trim : FOR SALE PLZ CHK OUT Ebay
    Engine : Z19DT
    Mileage : 119000
    Default Turbo seals? 1.9 CDTi 120
    Hi All,
    Any one else noticed oil on the compressor side of the GT1749, replaced jubilee clips with some nice shiny s/s ones, thought i had done up tight but boost pipe from compressor housing had blewn off, before i refitted i noticed that theres engine oil blasted all over the exhaust heat sheild, back of cooling fan etc.
    Wouldnt say its loads n loads of oil but more than i would expect, esp for such a short amount of time pipe was off, what sort of oil residue should be expected in the boost pipes if any?
    If anyone can confirm if my turbo needs an overhaul if so wheres the best place to source turbo rebuild kit. seen them on ebay but doesnt confrim they are genuine garrett parts, would pefer genuine garrett parts tbh.
    Many thanks
    Leroy.
    lincolnshire
    there should be a small amount of oil in there but not the amount your describing ! though having serviced a good few dervs , they seem to spit wet soot and oil out fromt the turbo area quite a bit with no side effects
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    I thought mine had gone too, oil everywhere, I eventually traced it to where the dipstick tube mate with the sump, the bolt had come loose allowing oil to blast out there covering everything. Since doing that up no more oil patches under the car.
  1. Valve stem seals. Do they go on the Vectra C CDTI
    By smiley-sri in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2016, 06:27
  2. sri v6 cdti turbo?
    By broad in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2012, 22:19
  3. 1.9 cdti injector seals
    By Dilly in forum Engine & Drivetrain
    Last Post: 21st September 2011, 13:55
  4. CDTI 150 Injector Seals
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 14th August 2011, 19:56
  5. 120 cdti turbo
    By markgcdti in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2011, 17:15
sri cdti 120 turbo seal
vectra c 1.9 turbo seals
vauxhall vectra c 1.9 turbo seal
1.9cdti turbo seals
