Results 1 to 10 of 19
Thread: Towing help
    Jul 2011
    UK
    Year : 06
    Default Towing help
    Someone tell me how to tow on normal licence my mate saying he can tow a 2.4 ton with his 1.5 dci scenic someone tell me the rules
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    If he has a normal license like me and you both trailer and the car can not exceed 3.5 tonne you have to add both the max weights up if it's over 3.5 then no he carnt think he will blow his car up aswell
    Jul 2011
    UK
    Year : 06
    Cheers Paul nu I was right lol
    What does a vectra weigh
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    I think he is talking out his rear end mate. Look up the dvla site you will get the info you need there.
    3.2 v6 Signum and loving it
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Er not sure fella would think near 2 tonne I would think
    Jul 2011
    UK
    Year : 06
    Vectra is 1400 last time I remember ya can't tow anything that weighs more than a car he would need a landrover ect which means he needs to upgrade his licence correct me if am wrong
    Regular Member poves's Avatar
    lancashire
    It really is a massive grey area where the law and vosa are concerned , alot of them don't know the rules themselves .
    All I can say for definate is if it's over 750 kg it needs brakes on the trailer , and the towing weight rating will be on the tow vehicle .
    Also you need the relevant category on your licence .
    I've just been through the in's and out's of this as I needed a new work van / truck that I could tow cars with.
    I ended up with this little beauty
    Dec 2011
    Seaham
    Personally I wouldnt try and tow anything over 90% of the Kerb weight of your car. The recommended tow weight may even be less then 90%.
    You can generally tow with anything, but it is how safe the outfit is.
    Snaking generally occurs because the towed vehicle is trying to push the towing vehicle forward, notably happens whilst going downhill or trying to slow down.
    As per previous post, max weight un-braked is 750kg including the trailer.
    Sep 2011
    Kent
    We tow a caravan, you need to be very careful, as said look on dvla or vosa websites as can change on date you go your licence.
    Load the trailer/caravan correctly, make sure the nose weight isnt over your limit.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Where to start
    Anyone who passed their test after 1997 can tow a trailer up to 750kg with ANY vehicle up to 3500kg (that means the total train weight is 4250kg)
    The exceptions are
    You can have any mixture of a vehicle/trailer outfit so long as...
    • The trailers laden weight does not exceed that of the unladen weight of the tow car
    • The trailer does not weigh any more than the towing limit of the vehicle (that one is kinda obvious)
    • The total train weight doesn't exceed 3500kg (this is the weight of the laden trailer plus the fully laden vehicle, it doesn't matter if the car or trailer are not at their max weights. It goes by the plated weights
    The example I can give you is an all too real one
    I have a swift corniche caravan and it's total laden weight is 1250kg
    My Vectra 1.9 CDTI SRi weighs 1456kg unladen
    Meaning I am well under
    The car's towing weight is 1600kg
    Again well under
    The laden car weighs 2005kg so 2005kg+1250kg=3255kg......and again well under
    HTH
  1. Towing a car with no tax or MOT
    By Gayno in forum The 'Off Topic' room
    Last Post: 22nd October 2010, 21:37
  2. Towing?
    By Si Jonz in forum Suspension, Wheels & Brakes
    Last Post: 19th October 2009, 12:51
  3. towing a car
    By steve.s in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2007, 18:39
  4. Towing Eye
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 08:49
  5. Towing
    By BigLick Round Roundabouts in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2005, 16:46
