Thread: diagnostic readout
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    Default diagnostic readout
    just looking for thoughts on this
    car runs fine and no major probs
    just a couple of warnings sporadically appearing on cid screen
    which clear when button is pressed
    everything seems to work ok.
    car was serviced and a quick printoff of diagnostic history as below
    was told cim module could be on its way out but to see how it goes.
    faults have been cleared to see if they reappear.
    DIAGNOSTIC REPORT: 090821d
    weston auto tune
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0003
    VIN: W0L0ZCF6828092005
    Part Number:13112784
    Software version number: 805050111
    System description: EATON0400.............................cim module behind steering wheel
    Alpha code:
    Manufacturing date: 020507
    Number of stored fault codes: 10
    B3700 - Wiper Interval Circuit Malfunction
    (0F) - Not present
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    B2657 - Illumination Circuit Malfunction
    (00) - Not present
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (00) - Not present
    U2108 - CAN-Bus No Communication with ABS (Anti-Lock Brake System)
    (00) - Not present
    U2111 - CAN-Bus No Communication With EHPS (Electro-Hydaulic-Power-Steering)
    (00) - Not present
    U2120 - CAN-Bus No Communication with AHL (Headlamp Levelling Device)
    (00) - Not present
    U2116 - CAN-Bus No Communication with IPC (Instrument)
    (00) - Not present
    U2141 - CAN-Bus No Communication with REC (Rear Electrical Centre)
    (00) - Not present
    U2113 - CAN-Bus No Communication with SDM (Sensing & Diagnostic Module, Airbag)
    (00) - Not present
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0303
    System name: Z32SE............................................. ................. engine management
    Hardware number:61206832
    Part Number:55351519
    Software version number: 27470303
    System description: BOSCH0100
    Type approval number: B02003
    System description: 0x20202020202020202020202020202020
    Alpha code: QW
    No fault codes stored.
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x0301
    Hardware number:12790842
    Part Number:9191497
    Software version number: 00C32B2E
    System name: ESP EBC430
    System description: TRW 0300 ...................................abs / traction control / electronic stability program
    Alpha code: EP
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0101
    Hardware number:24444336
    Part Number:0
    Software version number: V11_
    System name: EHPS GEN3 TRW............................................... electro hydraulic power steering
    Alpha code:
    Source Address: AHL/AFL
    Source Address: 0x00000249
    Identifier: 0x0101
    Hardware number:12787311
    Part Number:24417112
    Software version number: 00C31947
    System name: AHLS Epsilon........................................... ....................... auto headlight leveling
    System description: HELLA0401
    Alpha code: RY
    Manufacturing date: 02400240011103280224
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x0100
    Part Number:24402317
    Software version number: 3.29 38/01 ............................................instru ment panel cluster / dash
    System description: VDO 0400
    Alpha code: XE
    Manufacturing date: 020311
    U2120 - CAN-Bus No Communication with AHL (Automatic Headlamp Levelling)
    (7F) - Not present
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0001
    Part Number:13129843
    Software version number: 00BA9224
    System description: DELCO0400
    System description: 0x415339383433483332313330424B4E4B................ ........................ airbag ecu
    Alpha code: CL
    Manufacturing date: 020510
    Source Address: PAS
    Source Address: 0x0000025B
    Identifier: 0x0101
    Hardware number:50
    Part Number:9229754
    Software version number: 00000029.......................................... ............... park assist sensor
    System name: PAS
    System description: BOSCH0400
    Alpha code:
    Source Address: BCM
    Source Address: 0x00000252
    Identifier: 0x0203
    Part Number:9226555
    Software version number: C08C20 33014001
    System description: TEMIC04
    System description: 0x20202020202020303030303234303536................ ............... body control module
    Alpha code: CN
    Manufacturing date: 202020202020
    Number of stored fault codes: 2
    B3057 - Security Code Not Programmed
    (00) - Intermittent
    B3916 - No Communication With Alarm Siren
    (0F) - Not present
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0101
    Part Number:13125488
    Software version number: 0000038D
    System name: REC
    System description: LEAR 0400
    Alpha code: BA................................................ ................................... rear electric control
    B3445 - Rear Left Brake Light Circuit Open
    (04) - Not present
    B3596 - Invalid Trouble Code Please Ignore!
    (00) - Not present
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0101
    Part Number:13112919
    Software version number: 0000038F
    System name: UEC
    System description: LEAR 0400 .................................................. .........underbonnet electrical control
    Alpha code: AL
    (00) - Not present
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0201
    Part Number:9227565
    Software version number: OP1D 186000 ......................................driver door module
    System description: SIEM 0401
    Alpha code: KM
    Manufacturing date: 612020
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0201
    Part Number:9227563
    Software version number: OP1D 186000............................................ . passenger door module
    Alpha code: KQ
    Manufacturing date: 122110
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x0202
    Part Number:9228718
    Software version number: 08.26b 08 10................................................ ..... coilpack
    Alpha code: QZ
    Manufacturing date: 020416
    Source Address: ECC
    Source Address: 0x00000248
    Identifier: 0x0104
    Hardware number:9228184
    Part Number:24441229
    Software version number: C313 0100101........................................... ......... electronic climate control
    System name: ECC 3200
    System description: 0x33383831383420000200040300304333433000
    Alpha code:
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    I would....
    Remove and clean the indicator / cruise stalk with Contact cleaner
    Remove the big multiplug at the back of the CIM and clean with contact cleaner
    Remove the ABS multiplug from under the bonnet and clean with contact cleaner
    Remove and replace the fuse for the CIM in the fusebox.. Cant remember the numbers - i think its fuse 17 and 24, but will check for you.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    They are all Not Present so i would get them cleared then check again after a week
    Irmscher Insignia CDTI 130
    Middlesex
    Trim : SRI
    Mileage : 100k
    .....fuse 17 and 26
    Agree re the above.. but you say that they sporadically come back - so a good contact clean as I say will help I think
    Regular Member krazylegz's Avatar
    South Shields
    Without sounding thick what's CIM module?
    Mar 2012
    paisley
    re. cim module
    it seems a common vectra part to fail if you google it
    by the looks of things it sits behind steering wheel and houses the ignition barrel and transponder/ wiper and indicator stalks / steer angle sensor / airbag activation and maybey more?
    if you need to replace one it needs coded to vehicle and there is a lot of communication going through it via canbus.
    cheers fellas
    i had faults cleared and going to check on it at a later date.
    as its not giving me major problems im not mega bothered
    i have experience on more complex control systems like this on hybrid plant and vna machines and im aware there can be lots of sporadic fault glitches getting logged through canbus errors or by someone working previously on the equipment and removing plugs etc when system is live.
    only glitches i have is a recurring " check safeguard" coming up on the screen
    rear bumper sensor intermittently working. rear left brake light
    im gonna check out the rear electric area plugs and fuses as its in that area with alarm siren.
    thing that threw me is the b3057 security code not programmed
    does this mean a part has been replaced and not set up for coding
    or has/can the keys/imobilezer coding been switched off due to a new cim module then these codes not cleared?
    also the date stamp on the cim is 020507
    dont know what format thats in
    5th feb 07
    7th may 02
    2nd may 07 ?
    cheers again
  1. 1.8 maf readout...
    By Marvec in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 18:31
  2. Z19DT OP-COM readout
    By Astra H in forum Engine & Drivetrain
    Last Post: 30th April 2011, 13:28
  3. Anyone with a 'live readout tool' and 2.0T do me a favour?r?
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 22:03
  4. Trip Computer live MPG readout.
    By pete63 in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2008, 21:36
  5. mpg readout
    By skippyroo in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2007, 20:03
Vauxhall DTC U2113-00
opel fault code u2113-00
u2141 vectra c
u 2120 vectra
u2120-7f
B2657 vectra c
dtc u2120
u2141 fault code opel astra
Vauxhall DTC B3445-0B
vauxhall fault code b3445
astra h u2141
u2141 vauxhall code
ipc ecu fault code b3057 zafira b
aflahl headlamp levelling no communication
0pel u2120-00
u2120-7f
opel vectra u2120-7f
astra h fault code B3445
opel Astra H 2005 code u 2141
Opel DTC U2113-00
