Thread: Does Anyone Know ?
    Regular Member dazmufc's Avatar
    Aug 2011
    West Midlands (Oldbury)
    Vehicle : Vectra C Estate
    Trim : SRI XP2
    Engine : Z22YH
    Mileage : 72750
    Default Does Anyone Know ?
    How many & what size jubilee clips do i need to change my thermostat as i am a novice when it comes to car mechanic's. I've had a read of the how 2 & it just says a selection of small & medium.
    Daz
    Jul 2011
    UK
    Year : 06
    Go buy a selection of small and large lol sorry no idea was going do mine but decided nope cos il **** it up lol
    Dec 2011
    Seaham
    Measure the diameter of the pipes you are taking off, and then buy appropriate jubilee clips to suit.
    Regular Member coldo's Avatar
    Scotland
    When I changed mine on the Vectra I managed to use the original clips... Worked a treat... just a bit of a pain to use compaired to jubalee clips!
    Feb 2011
    Selby
    In general you can just reuse the existing clips - on the 1.8 at least (and I think at least on the other petrol models) just squeeze them with a pair of pliers (or molegrips) and slide the clip 10cm or so back down the pipe. Then pull the pipe off. To refit, just squeeze the clips again and slide them back up.
    11 Post(s)
    Quote Originally Posted by coldo View Post
    Quote Originally Posted by rich r View Post
    I used the same clips on my 2.2 when I changed the stat.
    Aug 2011
    Trim : SRI XP2
    Engine : Z22YH
    Mileage : 72750
    Thanks for the replies guys. I think I'll buy some just in case.
    All i need now is for the rain to p*** off for an hour so i can get it done
    Jun 2011
    Herts
    if you buy the QH kit for the stat it will have a large one in it- but as said above- you won't need it unless you lose one lol
    Aug 2010
    Derbyshire
    I bought a selection around the sizes I needed, only around 50p each anyways.
    Mick
