Thread: how to change the front reading bulb
    Regular Member Patrick's Avatar
    Jun 2006
    Singapore
    Default how to change the front reading bulb
    Hi all,
    i'd check the "how to" section but was not posted. Anyway, was thinking to change to some white light but wonder how do i remove the map reading light cluster. Hope you guy dont find this too stupid to answer.
    Tks in advance.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    If your just changing bulbs you only have to remove the glass panel by popping it off and then the bulbs should just pull out. Use a small screwdiver with some cloth round it to remove cover.
    Regular Member Orka The Porka's Avatar
    Oct 2006
    North Rochford (The Posh End)
    Becareful as the lights can also get hot. Best to do it in full daylight not ith the interiour lights on!
    If I remember correctly you have to remoive the glass bit to take the binnacle down from the roof anyway.. there are a couple of screws behind the glass and a couple behind the sunglass holder or blanking plate.
    As already said, if you are just changing the bulbs, you can do it with the light still in the roof.
    Jun 2006
    Singapore
    guys, tks for the prompt replies.....the vec B one is so easy to remove as it was just a smaller piece, the new vec C come with a big one, (well, everyhing grow in size...lol. ) so now i know is just have to pop in down....will try it soon. tks.
  1. Whats the best way to change a Vauxhall Vectra 2004 SXI Front Fog Bulb?
    By VauxhallBoy in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2012, 09:00
  2. Front light bulb change
    By Vectrarmand in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 15:54
  3. Vauxhallvectra c front map reading light
    By PAULMAC77 in forum Styling
    Last Post: 25th March 2009, 14:07
  4. How to remove front cig lighter and change bulb
    By Jay-C in forum Bodywork & Interior
    Last Post: 1st February 2009, 16:38
  5. Front Map Reading Light Upgrade
    By PeterVV in forum General Chat
    Last Post: 6th January 2008, 23:08
how to remove map reading light in vectra c
vectra map bulb replacement
vectra reading lights replace
