Results 1 to 10 of 19
Thread: Strange noise from front left going downhill
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Strange noise from front left going downhill
    Hi guys,
    Bit of an issue with the vectra.
    Going downhill, the front left has developed a horrible grinding sound that takes a while to disappear. The noise seems to disappear under braking. This grinding only seems to happen going downhill. If stationary and moving the steering wheel to the right there is also a strange noise but there is no noise moving the wheel to the left.
    I have also seem I have a low speed steering wheel wobble that stops once I go over about 40 mph.
    I thought it may be something to do with the brakes on the front left but at no point does the car pull to the left.
    Any ideas on where to look first?
    All advice appreciated muchly.
    Russ
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Check your wheel nuts are on tight for starters. I had an intermittent noise from the left wheel years ago, wheel was loose
    Mar 2007
    Grimsby, Lincs.
    Would that cause the noise going downhill only?
    Makes sense for the speed wobble though.
    Aug 2010
    Leeds
    Jack it up and spin the wheel any noise? and play in the wheel grab it and rock it up and down, side to side?
    Next take the wheel off for a visual check off all componants.
    The tyre could be out of shape which will cause the vibration at low speed.
    Mar 2007
    Grimsby, Lincs.
    Any more ideas before I jack her up?
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Check you haven't got a small bit of gravel or something caught inbetween the disk and the small lower ball joint protection shield, quite common.
    Mar 2007
    Grimsby, Lincs.
    Cheers Ian, I'll check for that in a mo
    Regular Member adierolfe's Avatar
    Feb 2012
    Corris
    I too have the noise that goes when the brake is pressed. Mine happens when I'm on the brakes a lot down a mountain.
    Had new pads and discs in Feb.
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by adierolfe View Post
    That's it, mine is only happening going downhill on the brakes
    Mar 2007
    Grimsby, Lincs.
    Right. Off to take the wheel off! Hopes its something obvious and inexpensive!
  1. rattle noise on left front wheel
    By mtqn in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2012, 19:50
  2. Noise from left front wheel :-(
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2012, 10:31
  3. noise front left
    By msqualo in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2011, 01:05
  4. Strange noises from front left hand side
    By RoddyKFC in forum Troubleshooting
    Last Post: 29th June 2009, 03:33
  5. Strange BC miles left thing
    By Whoosh in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2007, 14:44
