Thread: 2.0T Hesitation
    Regular Member GoldenWonder's Avatar
    Durham
    Default 2.0T Hesitation
    My 2008 2.0t seems to hesitate quite noticeably from cold. Its not like a misfire, just like its really down on power - this only seems to last for the first 1/2 mile or so and then it settles down to more normal behaviour.
    I've got a clean pipercross filter in and 4 brand new NGK plugs in (the correct ones!) and that made no difference.
    Is this normal for the 2.0t or is there something else I should be looking at? I seem to remember my previous 1.8VVT was similar.
    I also bought a code reader on ebay and plugged that in - no codes stored at all.
    Staffordshire
    I had similar issue and it turned out that one of my oil feeder lines to the turbo clogged and the compressor suffered from lack of lubrication until the engine warmed up.
    lincolnshire
    i'd take the advice above and check it out ;-))
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Water temperature sensor? Seeing as this controls lots of other parts on the car.. might be worth doing for the minimal cost?
    Did mine as i was having issues too.. helped it.. although turned out to be the coil packs.. so changed all 4 as i didn't know which one.. Mmmmmmmmm im in love with her again!
    Durham
    Hmm got me worried now! Its only got 38k on it so I was hoping it might just be plugs etc. Might try the water sensor next as its cheap. The coils are expensive at 75 quid each so theyre last on the list. How would i check for a clogged turbo oil line?
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Coils are half that price at Neo Brothers, that's where I got my replacements from.
    Durham
    Thats more bearable! Its ok after a mile or so so it does seem temperature related.
    Jun 2009
    South Coast
    Try the CTS First as that's cheaper. What petrol do you use?
    Durham
    I've been using a mixture of petrol recently - usually just standard Esso or Shell stuff with a supermarket fill up when I'm stuck.
    I notice on my other thread people seem to swear by super unleaded on these engines - I've never had a turbo petrol before so I've never really used super unleaded as it didn't make any difference
    Jun 2009
    South Coast
    My preference is Shell Vpower, I would never use normal unleaded in mine unless there was nothing else and even then just the smallest amount i needed before i could fill up with some proper stuff. I do use Tesco Momentum on occasion as its near to my work and my engine it quite happy to sup it.
    You may want to try running three full tanks of Vpower similar for a while to see if it sorts anything, I would also recommend shoving some injector cleaner into one of the tank fulls as well.. plenty to choose from, i have used redex and STP injector cleaner in the past. I run these through once a year on average.
    Nothing to loose..
  1. Hesitation help
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 21:53
  2. Hesitation please help??
    By sowter28 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 17:43
  3. hesitation
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 1st April 2010, 18:44
  4. Hesitation
    By Deadman in forum Engine & Drivetrain
    Last Post: 5th July 2008, 18:40
  5. hesitation
    By pogo in forum Engine & Drivetrain
    Last Post: 26th March 2006, 21:06
vectra 2.0t hesitation
