Results 1 to 10 of 14
Thread: rear skirt for dual exits
    Mar 2012
    Walsall
    Default rear skirt for dual exits
    i have a facelift signum with no visible exhausts out of the back of the rear skirt. i would like to get dual exit exhausts out of the back in order to tart it up a bit.
    this is where the confusion starts...
    i dont know what i need to buy..
    i have seen the pre-facelift rear skirt which is black and would need painting
    i have also read that the skirt i have should have a detachable insert in the middle (which it does not)
    so does that mean i have to replace the entire rear skirt?
    this is what i have at the minute:
    also, just out of curiosity, is the insert on the signum the same length as the Vectra?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Either use a hole saw and just bore it out and get some tips welded on or you'll need to change the skirt. The siggy skirt on the preface is one piece with inserts around each pipe but i think the facelift has an insert which apparently is different to the vectras insert
    Mar 2012
    Walsall
    but my insert is not an insert.. it is a moulded part of the bumper.. thats what confused me..
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Sorry, i think the skirt with the holes for the exhausts has an insert. I have an irmscher skirt (for irmscher single exit exhaust) that looks like a vectra sri skirt. I'm thinking of making/ modifying an insert to fit in it.
    Regular Member gibbon7000's Avatar
    lincs
    PM sent
    Mar 2012
    Walsall
    if the vec vxr insert was the same size, i'd do a bit of modifying to make that fit..
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by gibbon7000 View Post
    PM sent
    Dont tell me that you have a signum facelift bumper with twin exit insert in star silver???
    Apr 2011
    Las Vegas
    i have just fitted a twin insert onto my single insert facelift design, that bit should just unclip. It is also held in with 4 plastic rivit things. The insert cost £48 all in with p&p and new fittings.
    Mar 2012
    Walsall
    Quote Originally Posted by rob1981 View Post
    nope.. trust me, its moulded, its a single entity..
    Apr 2011
    Las Vegas
    random, guess you need the whole thing, painted part and dual exit trim.......
  1. cdti estate rear twin exits
    By winnie2457 in forum Diesel Engine related
    Last Post: 5th July 2010, 00:14
  2. dual exits, 1.9 CDTi
    By GARY3306 in forum Styling
    Last Post: 23rd January 2009, 10:43
