Results 1 to 10 of 15
Thread: Air compressors, any gen?
    Nov 2010
    Maidstone
    Default Air compressors, any gen?
    Have taken delivery of this air compressor as a freebie but i know nothing about air compressors and just wondered seeing as its a fairly small one what i could do with it, says on the tank 8psi? Any help appreciated
    Jan 2006
    Dalriada
    I would be surprised if the pressure is as low as 8psi buddy. The pressure switch is under the black cover above the gauges, you will be able to adjust the cut off pressure via this.
    What size is the receiver, 20 or 30 litres?
    Nov 2010
    Maidstone
    Shows what i know about these, i think its 115psi max, which could be 8 bar, not sure on tank size as its work, but i thought if it could be used to inflate tyres, use on spray guns etc i would keep it.
    Handy bit of kit imo ...............
    Nov 2010
    Maidstone
    Bereaing i mind i know very little, do you think i could use this kit on this compressor, would it run the items ok. Thanks for your help.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    It's not that small!!!
    gwent
    Only trouble with a small tank if you are using tools like a airgun or spray gun then the motor on the compressor will be running all the time as the some tool need a lot to run them best size 250 litre tank
    Nov 2010
    Maidstone
    Jan 2010
    glasgow
    its a 25lt or 50 lt tank by the looks of it you would spray a wing or boot sp or the likes but dont see it runing many air tools tbh
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Will easily run those tools in your link and others ..looks like a 50 ltr tank to me
  1. Air Compressors??
    By Leemarksmith in forum The 'Off Topic' room
    Last Post: 14th March 2010, 00:24
  2. Spring compressors
    By Middo in forum Suspension, Wheels & Brakes
    Last Post: 2nd September 2009, 21:45
  3. spring compressors
    By LOCKSTOCK in forum Suspension, Wheels & Brakes
    Last Post: 7th September 2008, 17:05
  4. Spring Compressors - Any Advice?
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 12:34
  5. Spring compressors
    By Jay-C in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2008, 08:24
airmate tornado 21025 manual
