Results 1 to 10 of 21
Thread: what would cause all these airbag fault codes?
    Regular Member krazylegz's Avatar
    South Shields
    Default what would cause all these airbag fault codes?
    As above what would cause all these fault codes on my 2003 Vec C 2.2 DTi?
    Tried putting it on opcom but they're not clearing?
    Engine : 1.9 CDTi
    Did they all just suddenly come on or have they always been there?
    South Shields
    Just really come about when I changed the dash harness, and both front airbags and airbag ecu. Could the airbag ecu I put in be faulty?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Where did you get the airbag ECU, was it a new one or out of an old car?
    South Shields
    Out of a car in the scrappy. The same car I got the dash harness, and both front air bags from
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Was the ECU divorced from the car, if not I dont think it will work.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Did you fit a harness from a car from the same year?
    Did the original airbags have a single plug?
    Did the ones you got from the scrappy have two plugs?
    Regular Member kns's Avatar
    Northampton
    You need the same ecu as yours ie the prefix letters need to be the same as your car.
    Mine was KN so replaced with one with the same KN letters.
    very easy to do and this will not need to be tech 2'd to your car.
    It's just a simple plug and play I know because this is what I done and it saved me over £600 from the steallers.
    South Shields
    Yes mate my car originally had single plug airbags and the new harness had twin plugs..... This car is beginning to turn into a pain in the arse lol.
    So I basically need the current ecu tech 2'd or try and get a twin plug ecu with the same starting letters as my old one?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by krazylegz View Post
    You have to replace like for like. The twin plug airbags and harness are not compatable with your car. For a start your car is half canbus and the donor car was full canbus.
    Unfortunatly everything you have got from the breakers is useless.
    You are going to have to find the parts from a half canbus car and the same Airbag ECU.
    Why are you doing this anyways? Did all your airbags go off?
  1. Airbag error codes
    By killa_uk in forum Vectra C / Signum Troubleshooting
    Last Post: 9th November 2013, 12:42
  2. Airbag Fault Codes
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2013, 00:49
  3. Airbag ECU fault codes ??????? ?
    Last Post: 12th September 2011, 20:39
  4. Can someone please help. AIRBAG FAULT
    By Bigg943 in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2011, 22:32
  5. Airbag ECU fault
    Last Post: 2nd February 2011, 23:22
