Thread: Fuel Filter Replacement - Z30DT
    Regular Member ph67's Avatar
    Northamptonshire
    Default Fuel Filter Replacement - Z30DT
    Is there a How 2 or does anyone have one that they could post for replacing the Fuel filter on the Z30DT please? Thanks
    Regular Member Johnny-B's Avatar
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Screw out old filter, clean the filter body inside from old fuel and dirts, its better if you filll in new fuel, change gaskets and insert filter!
    As there isnt pump in tank its recomend to blow air in tank while starting engine first time!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If ifs sane as y30 then theirs 2 fuel pipes unclip by carefully using a small flat blade scredriver oress down on blue tabs.
    Unscrew the screw
    remove lid an filter
    gently wiggle an pull on filter body.
    Poor old diesel into suitable container
    use small amount if fresh diesel to swill out any swarfe
    place housing back
    place in new filter
    fill will diesel/ 2 stroke oil
    ensure renew o rings
    replace lid an fuel pipes
    fill remaining oart of furl filter through screw hole
    replace screw
    They can be a ****** to start to due to no lift pump in tank but just fill filter through screw hole till its completely full an will start no problem
    Hope that helps
    adam
    Jun 2015
    Riga
    8 Post(s)
    Trim : Elite custom
    Engine : 3.0
    Mileage : 95kMiles
    How about How2 replace in tankt intake filter? Is there any? What is replacement number?
  1. Z30dt fuel filter question.
    By ScottyV6 in forum Y & Z30DT Specific
    Last Post: 21st November 2012, 23:41
  2. 1.8 Petrol - Fuel Filter Replacement
    By wafoo in forum Engine & Drivetrain
    Last Post: 7th August 2012, 16:09
  3. Fuel filter replacement - Y30DT.
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 11th November 2011, 23:51
  4. Z30DT fuel filter
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 20:53
  5. Fuel Filter Replacement
    By Dedrater in forum Engine & Drivetrain
    Last Post: 13th June 2008, 07:56
z30dt fuel filter
73959 fuel filter
z30dt fuel pump sell
pic of vectra c z30dt engine
vectra z30dt in tank fuel pump
z30dt diesel filter change site:www.vectra-c.com
how to disconnect diesel fuel pipes from a vauxhall signum
vectra z30dt engine bay showing fuel filter
where is the fuel pump located on z30dt
image of fuel filter change on vectra z30dt
vauxhall vectra c screw fuel filter
