Thanks Thanks:  2
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: TPMS Warning Light
    Devon
    Default TPMS Warning Light
    Hi there,
    Please can anyone tell me if there is any other way to read a TPMS fault other than using Tech2? I think one of my wheel sensor batteries has gone but not sure which one!
    Also, once Iíve fitted the new wheel sensor can anyone tell me if it will need programming in, or will it be self learning as I already have TPMS fitted and activated?
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    They're self learning and have a maximum quoted battery life of 8 to 10 years.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    56 Post(s)
    Vehicle : insignia
    Trim : irmscher
    think they activate after a certain speed 20 mph iirc
    If you have a CID a warning will pop up on screen telling you what tyre is running low, same with display in speedo window.
    The way i checked mine was to let air out of tyres one at a time and drive to petrol station and warning popped up and i just inflated tyre back up HTH
    If it was a 05+ full canbus system you would be able to look on screen and it shows psi off all tyres
    Irmscher Insignia CDTI 130
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi m8
    if your getting a negative reading on 1 or more of the wheel sensors and
    your getting an amber light on the instruments then you do have a faulty
    sensor or it may possibly a slow puncrure but if youve checked that then
    its more likely the sensors faulty.
    when you get a new sensor fitted into the wheel then it will learn
    automatically with the reciever and function normally
    im having the same problem with my front n/s wheel sensor and i get the
    same faults as you.
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    Devon
    Quote Originally Posted by bigmac View Post
    Thanks for the info.
    The actual system is working and throws up warnings when tyre pressure drops. The problem is that the fault light indicator has lit up in the speedo. Iím pretty sure this is because one (or maybe more) of the wheel sensor batteries has given up.
    Are you saying that I can check which one is dead, by dropping pressure out of tyres one at a time and whichever one/ones do not register a low pressure warning on my CID are the sensors that need replacing?
    Devon
    Quote Originally Posted by andy.l View Post
    hi m8
    same faults as you.
    Thanks mate. I'm not getting a negative reading on any sensor on my CID - only the orange fault warning light on the speedo - hence I do not know which wheel sensor needs replacing.
    Devon
    56 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Well if the sensor is faulty it wont pop up on display, if you leak some air out of each one individually and they pop up then by rights the faulty one wont display anything.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Doesn't the previous version show this info then? I don't want to hijack this thread but can anybody explain the differences between the two other than the amount of receivers..
    Devon
    56 Post(s)
    Vehicle : insignia
    Trim : irmscher
    The CD70 CID has an option to check TPMS and it displays the 4 wheels and their psi pressure, the NCDC CID only shows up on screen if tyre pressure falls below fresh hold
    Ely, Cambridgeshire
    58 Post(s)
    Year : 2010
    Quote Originally Posted by Caveman_nige View Post
    No, I've got the early TPMS system on mine, it only comes up on the GID with the pressure of the tyre that's triggered it and a small image of the car with an arrow pointing to the tyre on the lcd in the rev counter, there's no screen to show all the tyre pressures at once. I asked about this before as I would have liked that option and was told there is no way of doing it on this system. Basically if the tyres are all at correct pressures you don't see anything to do with TPMS at all and have no way of doing so.
  1. warning light
    By bigcarp1953 in forum Engine & Drivetrain
    Last Post: 20th August 2012, 06:41
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. warning light
    By J spoon in forum Introduce yourself.
    Last Post: 25th March 2010, 01:02
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
