Results 1 to 10 of 18
Thread: sub frame tool
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default sub frame tool
    has anybody got a tool for lining up the vec c subframe after removal?
    cheers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The front? If you look in the haynes manual it tells you how to make one up using a socket metal bar and two bolts. Don't have my manual at hand though.
    I made the tool and used it on my last car for changing the clutch
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    i had a look at that but couldnt understand where the holes were, and i need one thats already made as the subframe has been removed previously so not sure how i could make one up if the subframe isnt lined up correctly.
    Correct me if im wrong guys as i really havnt got a clue
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I just took mine off dumped it on floor.
    And then lifted it back in place after done the clutch.
    It all lined up fine.
    And even a full geometry check showed it was ok
    South east
    I don't think there is a ready-made tool for this; the kit that the dealers use is a huge mutha that combines the facility for lowering the subframe with the realignment requirement.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    There is a small round hole on the subframe (for the bolt) and a large hole on the underside of the car...you can't really miss it.
    If a member with a takes some measurements you can make the tool to the same measurements.
    As long as both sides sit the same (the tool fits into both sides without adjustment) then you'll be fine.
    I could take measurements off of mine tomorrow if you like. It had the subframe off for a new dmf at VX but that was 40k ago and has had a 4wheel alignment since that confirmed it's straight
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    if you could john that would be great m8, im just going over everything thats been done as im getting uneven wear on the front, and the sub frame is one of the potential causes
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    My cars on the pit this weekend (Upper Control arms) so I can take the measurements if you wish.
    Just thinking John will the facelift be different with the extra Chassis brace?
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    never thought of that.
    If you could that would be great m8
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Shouldn't think so bud as the hole on the subframe is right next to the wheel and the other is on the body of the car. The subframe on the facelift isn't actually that different when you look at it.
  1. Sub Frame Question
    By higgy1541 in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2012, 12:26
  2. Zimmer Frame...
    By macdad in forum The 'Off Topic' room
    Last Post: 21st July 2011, 23:21
  3. **FREE** Double Bed frame
    By craigbarlow18 in forum General items for sale
    Last Post: 4th January 2009, 19:00
  4. broken frame
    By parsco in forum Styling
    Last Post: 7th October 2008, 18:37
  5. DDG Shooter frame and forks £20
    By freshprince in forum General items for sale
    Last Post: 27th May 2008, 13:47
remove sub frame vectra c
