Results 1 to 10 of 17
Thread: Temperature Sensor?
    Regular Member JaceyBoy's Avatar
    Apr 2012
    Bournemouth
    Default Temperature Sensor?
    Hi Guys,
    Got a 2.2 Signum petrol and the temp sensor seems to take a while to come up and when fully warm only shows just under half warm, around 80oc, is this a sensor fault?, if so what sensor do I need?
    11 Post(s)
    More likely a failed thermostat.
    Easy enough to change.
    2 bolts and some fresh antifreeze.
    http://www.vectra-c.com/forum/showthread.php?t=156707
    Apr 2012
    Bournemouth
    Thanks but I cant see how its the thermostat, the gauge isnt iratic and it always warms up and cools down, its just the dial doesnt reach half way, do all of them reach half way when fully warm?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    Quote Originally Posted by JaceyBoy View Post
    are you diesel or petrol?
    Apr 2012
    Bournemouth
    Hi Guys,
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    well i changed my thermostat and it should stay at 86-88 and should not move
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    you will be using more fuel
    80 is to low
    Apr 2012
    Bournemouth
    Hmmm maybe it is then, where did you get one from?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    you could try a sensor i think they are around 12 to 15 pounds
    but its mainly the thermostat mine broke around 53000 miles
    what mileage has you car done?
    i got mine from vauxhall
    South east
    The dial wouldn't be erratic if the thermostat was faulty. If the thermostat is stuck open then the dial will be showing that the engine rarely reaches the correct temperature (except when stuck in traffic perhaps), or if it's stuck closed then the engine will be at too high a temperature.
  1. Outside temperature sensor gone mad!
    By devore in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2013, 16:58
  2. Outside Temperature Sensor
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2009, 23:35
  3. Outside air temperature sensor
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 13:31
  4. Outside Temperature Sensor
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2008, 10:59
  5. outside temperature sensor
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 17:23
