Thread: Preface - A question about headlights level motor
    Full Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Vectra C
    Trim : Estate F35, Elegance
    Engine : Y22DTR
    Default Preface - A question about headlights level motor
    I bought these:
    This is the back of the headlamp:
    This is the room for the motor for level adjustment:
    The seller told me that I can take the motor from the original headlight and put it there.
    I'm wondering if this is true...
    Any help or suggestion is welcome!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I take it a cover goes over that?
    If you remove the white thing then the motor will go in that hole.....just think there should be a cover to go over the motor though
    Trieste, Italy
    Engine : Y22DTR
    Yes, there is a cover. I removed it to take the pic.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Ok then, turn the white cap and then pop the ball joint out from inside the headlight (be careful). Then pop the ball joint of the headlight motor in it's place and turn it motor to lock it into the casing. The little white plug plugs into the motor
    Trieste, Italy
    Engine : Y22DTR
    ...a massive thanks!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No problem
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Watch though that ball joint can be stubborn. Was on my Angels but luckily I got the motor fitted.
    Trieste, Italy
    Engine : Y22DTR
    Just found this:
    http://www.vectra-c.com/forum/showpo...2&postcount=63
    And this thread was already on my "favorites"...
    Trieste, Italy
    Engine : Y22DTR
    ...and also this:
    http://www.vectra-c.com/forum/showthread.php?p=188287
    Superstuper... before asking something... please use the search button!
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by GazCDTI150 View Post
    Instead of trying to pop the ball joint together, just angle it slightly, push it so it's in line with the plastic joint and slide it in
  1. Headlight level motor
    By davidj387 in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2012, 23:04
  2. xenon self level motor problems
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2010, 11:42
