Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Need advice guys-CDTI 150
    Birmingham
    Default Need advice guys-CDTI 150
    Hey guys,
    As some of you have probably read im out of a job and hence am looking for a car on the cheap'ish.
    I went to see one today which is owned by an ex-colleague of mine so I know he is trustworthy, but I need some advice about the car.
    Its a 2005/54-reg Vectra 1.9 CDTI Design 150 which he has owned since it was 6 months old and has been fully serviced and maintained.
    But its not had a Flywheel problem YET, no alternator issues, cambelt not changed, and I have inspected the manifold and the bar is OFF and that bar area is covered in oil.
    The car has been standing for some time and he said its been running fine until he was given his company car. It pull perfect and gears, etc are all OK.
    Now the car has got 125k on it but about 100k of that has been done by the same person.
    My questions:
    - how long will the inlet manifold continue for in the current state, with the bar off and oil around that area;
    - how can I assess the the flywheel?
    Its got no MOT or TAX as its been standing but he is a very genuine guy and I worked with him.
    Other than that, its got one or two marks here or there but nothing critical, its all part and parcel of its age.
    Potentially I could get it very cheap.
    Your comments PLEASE.
    Bye bye Vec B
    - Hello Siggy!
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Some on here put swirl flaps at 10 o clock then glue into position
    Depress clutch with engine running you normally here a knackered DMF
    I ll try and find some links
    Birmingham
    Quote Originally Posted by troutybrown View Post
    But what about the oil surrounding the pots? I have no problem glueing the pots but doesnt it mean its totally scrooged if its oily?
    Thanks - link would be good!!
    Bye bye Vec B
    - Hello Siggy!
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    125k with no cambelt change, id wanna have a look at that...
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    As said above find out about cambelt and water pump
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    OK so firstly - you will NEED to do a cambelt before you start to drive it in any anger.. Dont risk running it mate at 125k with no cambelt change..
    A cambelt kit from VX I think is just over the £100 mark and you shoudl also do the water pump too...
    IF the dual mass flywheel is not rattling - thats a good sign.. Drive the car and can you hear it clunk / knock when the gear engages at clutch bite - or when you come on / off the power with a jerk - if so its likely to need it soon - BUT they can make a noise for YEARS and 1000's of miles without failing.. Expect to pay about £850 for full clutch kit and DMF change.
    Inlet - well - its failed already.. The swirl bearings will be shot.. BUT - if you can move 1, 2, and 4 freely (no 3 has a motor attached to leave that alone) then you can glue them open at the 10oclock position and it will run 'as normal'. That really depends on how worn they are mate...
    Alternator - you just dont know when they will fail.. Put the display in test mode and see what the volts are running at now.. Anything lower than 13.5 is a problem... They are about £150ish to buy.
    Shout if you need anymore matey....
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    as erni3wi5e said you dont want this
    http://www.vectra-c.com/forum/showthread.php?t=144725
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    member tony 1977 is the man to pm
    swirl bar
    http://www.vectra-c.com/forum/showthread.php?t=142503
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by AntSSSS View Post
  1. Need some advice guys
    By spennny in forum The 'Off Topic' room
    Last Post: 2nd November 2012, 13:46
  2. Need some advice please guys!
    By zoebeck1703 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th May 2012, 14:22
  3. advice please guys
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 19:58
  4. Hi Guys - I need some advice
    By rodminuk in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2007, 22:13
  5. Need some advice, guys!!!!
    By Drinky in forum Comedy & Humour
    Last Post: 19th October 2005, 21:49
