Thread: Aux Belt Tensioner
    Jul 2011
    Daventry
    Default Aux Belt Tensioner
    Hi, can anyone help
    Just changed cam belt but was beaten by the weather and the Aux belt Tensioner.
    I removed the tensioner and noted the routing of the belt, my problem is I dont seem to be able to position the tensioner in such a way that: -
    1 - It allows me to create enough tension in the belt
    2 - I am not actually feeling any tension when I move it, rather just the limited movement of the guide against the mounting location on the block
    I imagine i should be locking it somehow but just don`t seem to be able to make it work.
    Any help would be appreciated
    tatters40
    South east
    Which engine?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by Rebellion View Post
    Which engine?
    Good question
    Jul 2011
    Daventry
    confused
    Damn Fine Question
    CDTi 150
    Paul
    Jul 2011
    Daventry
    Anything Guys?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It does lock onto the side of the block, it just takes a bit of fiddling, then tighten the bolt that holds it to the block and use a spanner to turn the tensioner clockwise
    Jul 2011
    Daventry
    Sorted, the tensioner spring was fractured internally which did not allow it to spring back from the `locked` position
  1. fan belt tensioner
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 15th December 2012, 11:50
  2. Aux Belt Tensioner Help !!
    By keithtinman in forum Engine & Drivetrain
    Last Post: 25th July 2011, 21:57
  3. v belt tensioner
    By micks edition 100 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 00:10
  4. Aux belt tensioner
    By jamesr in forum Engine & Drivetrain
    Last Post: 15th December 2008, 20:56
  5. Aux belt tensioner on 3.2
    Last Post: 10th September 2008, 21:22
