Results 1 to 10 of 11
Thread: Cost of ABS Sensor Fix?
    Jun 2009
    Co. Durham
    Default Cost of ABS Sensor Fix?
    Hi Guys,
    Typical as I am putting my car up for sale in a week or so, that the ABS light came on.
    Garage put diagnostics on - Offside front ABS sensor. Apparently is comes as part of the wheel hub and cannot be replaced by itself.
    Been quoted either £158 or £182 all in depending on which of the two it is.
    Its a Vectra 2.2 Direct 56 Plate.
    Has anyone any experience of this and if this is reasonable?
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Just switch the light of lol
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    That's cost of the hub from Vx alone it doesn't sound too bad
    Nottinghamshire
    It may well be the sensor in which case it is a hub replacement job as stated above, but also check the wiring and connector under the wheelarch for damage/water ingress respectively.
    The warning light will go off when the fault condition disappears.
    scotland
    mine was the two pin connector that gave me the fault , just grafted on a new section of harness , 12 quid on the bay :-)
    Jun 2009
    Co. Durham
    Whereabouts is the connector located? I might try and have a look before giving the garage the go ahead to do the hub.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    behind the front left wheel..you have two electrical connections side by side. Ones the brake wear indicator..the others the abs plug,its a two pin connection.
    scotland
    no mate its the O/S , its on a clip on the inside wheel arch / strut driver side .
    just unplug the white connector an check it out . it goes to a short wire to the rear of the hub , there is a way to check voltage through this but I'd need to look as I dont know off hand ...... drink lol
    good luck
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by nikroc View Post
    The cable is about a tenner from VX.
    If it is the hub then
    http://www.ebay.co.uk/itm/Vauxhall-F...0#ht_500wt_715
    + Fitting
    Jun 2009
    Co. Durham
    Thanks again for the replies.
    I've had a look and the cable doesn't show any sign of damage and the connection is dry as a bone inside.
    Looks like it is the sensor.
    2 years of suffering nothing apart from a snapped coil spring then 5 weeks before my company car comes I get a £180 repair to do.
    I think they call that sods law :/
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
abs sensors on vectra cost
cost of fixing abs sensor
