Results 1 to 10 of 16
Thread: Help!! Broke down
    Mar 2012
    Kent
    Default Help!! Broke down
    Hi i was driving today and the clutch felt light. Now it wont go into gear any ideas what it could be.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    what is your mileage on?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep your clutch release bearing has gone. Is it leaking fluid (brake fluid), check the brake fluid reservoir and also have a look under the car.
    Only other thing is that the cable has snapped or the pedal box has broken (brackets that all the pedals mount in)
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    petrol or diesel
    Mar 2012
    Kent
    93500 1.8 petrol
    Regular Member coldo's Avatar
    Scotland
    If the engines running but the clutch is dead could rev matching allow gear change without the need for the clutch...
    Takes a bit of practive but is possible to do... No responcibility is taken if you kacker things more however...
    From another site...
    You may find yourself in the situation where your clutch cable has snapped or the fluid has drained out of your hydraulic clutch. You can't drive like that, can you? Well, actually, you can. All you need to know is described here:
    To start the car, put it into second gear, take off the handbrake and turn the ignition key. The engine will start, the car will jump forward and the engine will stall. Immediately, while the car is still moving, turn the key again. This time the engine will start and will continue to run.
    You can now drive. When you feel the car is going at the speed where you would normally change gear, rev it up slightly higher, then pull it out of gear. At the same time, ease off on the accelerator and push it into the new gear. With a bit of practice (and luck) you'll get a smooth gear change.
    Changing down gear is similar except that you don't rev up beforehand and you leave the engine longer out of gear so that it can slow down and match to the lower speed.
    When you want to bring the car to a complete stop, change down to a low gear, then brake heavily to cause the engine to stall.
    Mar 2012
    Kent
    No snapped cable or theres no fluid leaking
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    sounds like your clutch has gone
    my mates clutch went on his around 85000 miles
    his is a 2004 1.8 ls
    cost around 260 pounds
    mr clutch i believe
    Mar 2012
    Kent
    Ok thanks everyone. Ive managed to get it home, i was dreading the MOT yesterday but that passed and now the clutch has surprised me.
    11 Post(s)
    Quote Originally Posted by Zakstarr View Post
    No snapped cable
    I should hope not, seeing as it's a hydraulically operated clutch.
  1. Broke the ice ;) First Mod done :)
    By spikeyboi33 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2013, 22:16
  2. If it ain't broke don't fix it.
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 15:19
  3. Just broke broke bit of my dash
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 17:15
  4. Broke me car!!!!!
    By Jay Kay 313 in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 07:23
  5. Car is broke again....
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2008, 14:14
