Thread: fog lights
    Regular Member veccy c's Avatar
    Jan 2008
    rotherham
    Default fog lights
    Im thinkin of swopin my fog lights for some brighter ones but do i after take bumper off to change them
    Sep 2010
    all depends if you have an access panel underneath. I was advised my car had an access panel in the undertray,.. but it didn't at all so I needed to remove my bumper - easy and quick to do tho.
    Quote Originally Posted by veccy c View Post
    Surely that would make things worse in fog?
    Or is this purely a posing thing rather than for practical reasons?
    Full Member coldo's Avatar
    Scotland
    Prity sure you can get at them from under the bumper...
    Jack the car up at the front and secure oit on axcel stands...
    Get the bumper at look to the side of the bumper (where the fog lights are). You should see a large black box which is the same at both sides(this is the fog lights)...
    At the bottom of this should be a black screw cap. Take this off to access the bulbs...
    Failing that its a bumper off job... Take about 10 minutes to get the bumper off and is easiest with two people doing the work (someone to help lift and hold the bumper)....
    Have you checked out the haynes manual at all as it might have pictures!
    Jan 2008
    rotherham
    Thanks guys il look into it yea more for look than really using them for what they should be used for lol
    Scotland
    If it's for looks consider getting the white SMD bulbs instead as these look emence and are not as bright....
    Scotland
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Won't those strobe
    Jan 2008
    rotherham
    Quote Originally Posted by coldo View Post
    coldo how do these work just plug in as the normal bulbs would??
    Scotland
    Yeah as far as I know they just plug in like normal bulbs...
    On the strobing Im not 100% sure...
    If the fogs are on the can bus system they may flash but I have a feeling there not on the can bus system just like the astra so you may be fine...
    There are loads of differnet types on ebay... these ones however say they are spacificaly for the Vectra... That said it's no garuntee they will work...
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
