Thread: **Urgent help required - Idle Control Valve gasket**
    Oct 2011
    Aberdeen
    Default **Urgent help required - Idle Control Valve gasket**
    Hi guy's,
    Yesterday i cleaned my ICV on my 2003 GSI as per How 2. All went well until i nicked a corner off the gasket. All put back together and as i suspected the idle speed is all over the place, reving upto 2000 rpm and dipping as i slow down to almost stalling.
    Simple fix i thought and phoned Vaux dealers this morning, they tell me you can't buy the gasket on it's own and comes part of a new ICV kit and wanting £700
    Please tell me there is a way around this without having to pay £700? alternatively make my own gasket??
    Pic of gasket in question:
    Jan 2006
    Dalriada
    Is it a paper gasket buddy? If it is i can send you gasket paper to make a new one?
    Sent from my X10i using Tapatalk 2
    Oct 2011
    Aberdeen
    Quote Originally Posted by Steven View Post
    Hey mate,
    It is a paper gasket. On doing vairous seaches it looks like there isn't a gasket listed and you need to purchase the complete TB. Thanks for the offer but i'll be able to pick up some gasket paper from a local motor factors for 40p and make my own.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    Quote Originally Posted by Bloicy View Post
    Hi guy's,
    was you thinking i wished id never started it now?
    if it works leave it
    Oct 2011
    Aberdeen
    Quote Originally Posted by vectra ste View Post
    Lol, your not joking. I was getting a very minor occasional idle flutter so thought what the heck i'll give it a clean. In fairness it did need a clean but typically i make a job worse than before i started.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    well i hope you get it all sorted out
    i take it the engine man light has been ok regarding the 02 sensor
    May 2011
    bispham, blackpool
    use instant gasket thats what i used on mine
    also do you have the link for the how 2 just been looking but carnt see it
    Regular Member poves's Avatar
    lancashire
    Quote Originally Posted by 6009tristanb View Post
    Same here , I used the high temp stuff (not that it matters) in a small tube , (about £7) worked a treat .
    Just make sure to do a nice neat bead , obviously on the inside area of the screw holes , place it square on in one hit if you can , as long as it oozes along the outer edges when you tighten the screws it should work a treat.
    Allow it to set before you start the engine though .
    Oct 2011
    Aberdeen
    I replaced the O2 sensor yesterday as the EML came on after 2 days of clearing. Thankfully the old sensor removed easily with a spanner and the light has remained off today so fingers crossed it's done the job.
    Here's the link to the How 2 mate.
    http://www.vectra-c.com/forum/showthread.php?t=35586
    Oct 2011
    Aberdeen
    Little update, bought a sheet of gasket from local motor factors and made one up myself. All fitted and purring lovely and not a flicker above 800 rpm, rev it up and drops straight back down and settles back on 800 rpm. Thanks for all the help and guidance, im over the moon.
  1. idle control valve 1.9cdti 16v
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 1st October 2012, 10:03
  2. 2.0 Turbo idle control valve
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 14:13
  3. 2.2 Non Direct Idle Control Valve
    By BaileySRI in forum Engine & Drivetrain
    Last Post: 19th February 2010, 17:22
  4. Help! 3.2 Idle Control Valve Gasket Needed (Leeds)
    By Hedgehog70 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 12:39
  5. where is the idle air control valve on the 1.8 16v?
    By glencol in forum Petrol Engine related
    Last Post: 18th March 2008, 08:41
