Thread: Steering wheel wiring
    Nov 2009
    manchester
    Vehicle : 1.9CDTI 150
    Default Steering wheel wiring
    07 1.9cdti ... past 2 years noise coming from steering column, past 6 months airbag light intermittent, now airbag light permanent + steering wheel radio controls gone haywire + intermittent horn… software reads
    Total number of fault codes: 2
    B0012 - Driver Airbag Squib Circuit (Stage1) High Resistance
    (0D) - Present
    B0013 - Driver Airbag Squib Circuit (Stage 2) High Resistance
    (0D) - Present
    Is this the clock spring wiring thingy and if so is it located in the wheel or the column cowling and is it easy to replace…
    Thank you
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I have a spare clockspring ribbon from a CIM i've acquired. I'll get the ident code from it tomorrow
    Nov 2009
    manchester
    cheers, but where is it located,,
    Aug 2010
    Derbyshire
    Take a look at this thread http://www.vectra-c.com/forum/showthread.php?t=162068 could be the same fault. Although my airbag light never showed, it just could be a bad earth. There is an "How to" for removing the steering wheel airbag, it is simple once you've fiddled with those release clips. I think my problem as in the thread was readjusting the earth spring piece at the rear of the airbag.
    Don't forget to disconnect the battery and wait 20 minutes.
    Mick
    Nov 2011
    CIM ident is EC for the spare ribbon if you need it
    Nov 2009
    manchester
    Sorted it at last. Removed CIM. Pulled CIM to bits. Cleaned all contacts and
    tested ribbon for resistance to find 2 circuits intermittent. The inner spool end of
    the ribbon had at some point kinked back on itself 3 or more times and jammed under the
    plastic tensioner thingy on spool. After straightening out it stabalized at 2.9 ohms on both
    circuits but when moved curcuit was broken so I araldited the first 2 damaged loops
    of ribbon on the spool, to the spool tightley whilst keeping a check on resistance
    using software then re assemled CiM back into car. Moved wheel lock to lock for ten
    minuites or so expecting disaster to strike, both stable at 2.9 ohms.
    Seems like jobs a good un.... Thank you for youre Help and advice...Thank you..
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. Steering wheel control wiring
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2011, 12:37
  3. Xtrons 714 Steering Control Wiring
    By daznkel in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2011, 19:28
  4. Replies: 6
    Last Post: 13th March 2011, 10:47
  5. Half-Can Steering Wheel Button Wiring
    By Gayno in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2010, 01:02
b0012 fault code
vectra c clock spring
Vauxhall DTC B0012-0E
Opel B0012
opel vectra c steering wheel control wires
vectra c air bag spool
vauxhall corsa fault code b0012
B0012 vauxhall
vauxhall airbag b0013
steering wheel wire opel vectra c
Vauxhall DTC B0013-0D
