Thread: Handbrake Cable Tightening
    Aug 2010
    London
    Default Handbrake Cable Tightening
    Hi there
    I was wondering is there a simple way to tighten my handbrake. I locks on about 6th click. I have read about people saying you can adjust the screw inside the car.
    Does this work?
    Another method I read was to remove the handbrake cables from the rear calipers, pump the brake pedal with ignition on and then reattach the cables. A guy re-posted in this method saying he went from 7 clicks down to just 4-5 to lock.
    Any advice guys would be helpful on how to tighten it slightly.
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    pump ya brake with the handbrake off then lift the handbrake if it don't work cable has stretched mate
    Aug 2010
    London
    thanks for reply.
    Iv tried that but it still only locking on 5-6.
    must be away to tighten it a little instead of new cable every time. I am usually very careful I don't pull to hard for that reason.
    would one of the methods I read about not work??
    thanks
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    They are self adjustin mate so no lol what are the rear pads like
    Aug 2010
    London
    the pads are new along with the discs.
    humm how come the guy said it worked when he removed the cables. pumped brakes and re attached the cables it work.
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Well he didn't do a very good job did he then every car I have done Vectra or a signing Wich is alot trust me have always bin 4 clicks after I have done them and I have only ever done it that way
    Aug 2010
    London
    humm
    I'm trying to avoid new cable, cause ant got ramps to fit it and then will cost even more money.
    What if i reset the spring just? surly it will start to re-adjust again making it tighter??
    would that work?
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Not sure Nate could be worth a try as I say I lol to do it right first time around lol
    Regular Member Craig1985's Avatar
    harwich essex
    Why not try, wind pistons back, re assemble rear brakes ,pump brakes, then apply hand break ( without pressing button)? Mine is fine after a pad change. Perhaps who ever changed rear pads last might not of applied brakes first to take up the slack in the cable?
    Aug 2010
    London
    Thanks for replies guys. I might try that.
    That would be easier than stripping gout the center console probably lol. If all fails looks like new cable i think.
    Any more suggestions keep them coming.
  1. handbrake cable
    By mbtech01 in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2013, 16:47
  2. Tightening handbrake??
    By SlowCoach in forum Suspension, Wheels & Brakes
    Last Post: 17th December 2012, 02:41
  3. Handbrake cable
    By peadar in forum Troubleshooting
    Last Post: 10th June 2008, 07:57
  4. handbrake cable
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 12:49
  5. Handbrake Cable - Tightening on a Corsa C
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2006, 19:25
