Thread: vectra 1.8 and 1.8 vvt difference
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default vectra 1.8 and 1.8 vvt difference
    I know it stands for variable valve timing and meant to be abit more economic but does the vvt drive different to the normal 1.8? My vvt i have now doesnt seem to accelerate as hard as my old standard 1.8 is that normal on the vvt?
    Barrow In Furness, Cumbria
    VVT is 140bhp, normal is 120bhp. When my VVT mech went it felt really flat. No power at all. Its in the engine troubleshooting section with the fault codes etc.
    Regular Member MACVVT's Avatar
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8 vvt (XE18XER)
    Mileage : 28,000
    changing gears at 3000-3500 rpm you should be doing 60mph + before going into 4th gear reving to 5000 rpm in 4th should see 100 mph, mine runs 150 bhp with cat back custom exhaust, 1.8 in 3rd gear should reach 80-90 mph , VVT a little bit more but achieves it faster.
    Sep 2010
    Leeds
    There is no faults shown or lights on dash. Is there a link? Was is expensive to sort your vvt mech out? Cheers
    The car with spanner light only showed with the ignition on after all the other lights had gone out. I'll get the link now.
    Sep 2010
    Leeds
    Just noticed the airbox had no pipe connecting it to front of car! Will that be affecting? And where can i get one?
    It will probably make a difference as it won't be able to breathe as intended. Get one from scrappers or ebay.
    Feb 2011
    Selby
    Do both the 1.8 and 1.8vvt you've driven have the same gearbox? The is a close ration gearbox or a wide ratio gearbox fitted to the 1.8 litre engines, depending on model.
    The more 'comfy' models (Elite, Elegance, Design etc) have the wide ratio gearbox, which is slower to accelerate, but cruises at a lower rpm. The 'sporty' models (SRi, SXi etc) usually have the close ratio gearbox which is faster to accelerate, but needs a higher rpm to do the same speed. For example, 60mph is about 500rpm higher in 5th gear in the close ratio models.
  1. XP & XP2 Difference
    By Jag.sri in forum Styling
    Last Post: 11th April 2012, 08:44
  2. Vectra C :difference between headlights
    By vaidisas in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2011, 17:16
  3. Difference between Vectra 1.9 120 and 150
    By Coupe2T in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2011, 18:42
  4. Difference between Vectra and Signum Exhausts???
    By luke4487 in forum Petrol Engine related
    Last Post: 11th May 2010, 19:58
  5. a vectra with a difference
    By dadstaxi in forum Styling
    Last Post: 27th April 2006, 17:35
vectra c whats the vvt stand for
what does vvt stand for on a vauxhall
