Results 1 to 10 of 22
Thread: Why why why y30dt.....
    Sep 2010
    norfolk
    Default Why why why y30dt.....
    Chaps, please help....
    Went out to start car this morning to commence normal daily drudge at some ungodly hour for a sunday and car refuses to start. Now that my mood has improved and am able to communicate with whole words.....
    Parked up last night with the usual issues that have plagued the car for the last 6 months or so, this morning turns over no issues, tries to fire but will not run, but now has spanner light on (new and exciting for today).
    Any thoughts on where to start tomorrow on my first day off in four weeks, my thoughts are currently local BP, unleaded and zippo.......
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by martyngell View Post
    When that happened to me, i got a mobile auto electrician to come and read the codes. he charged me £30 and advised me on what was needed to cure the problem. Always worth trying the pedal test to get the codes up on here. Someone might point you in the right direction before tomorrow.
    http://vectra-c.com/forum/showthread.php?t=81742
    Sep 2010
    norfolk
    Thanks mate, will try that when i get home tonight.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need your codes read mate as could be a number of things.
    Did car have any problems before parking up?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    As above anyone else thinkin scvs or is it just me
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Did think it mate. but would have to completely solid for it to not start.
    To the op try filling the fuel filter threw the screw hole and see if that gives any joy in getting it started.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Fair play mate also when to the op when did u last change the fuel filter
    Quote Originally Posted by paulvectrac View Post
    Extremely unlikely as the engine will run with a blocked SCV on idle
    More likely the fuel pump itself has failed
    As above, codes need to be read
    On the plus side, at least the warning light is coming on, all too often with this engine you get nothing!
    Sep 2010
    norfolk
    Thanks for that guys, will get codes read tomorrow. As for the SCV's, thanks but changed 6 months ago. Faults before this morning....
    Misfiring, vibrating at all engine speeds so yeah, a few faults..
    Will also try filling the fuel filter via the screw hole, did change the filter about 2k ago, but will try anything at present.....
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Ahhhhh, defo chance fuel filter. Those faults sound like when mine got blocked whilst on holiday. Shouldn't need to fill the filter. Just Turn ignition on and off a few times, should self bleed.
    I thought SCV's were only active in 5th & 6th gears?
  1. Y30DT - so is this the MAP sensor?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 1st January 2012, 18:58
  2. y30dt egr
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 08:43
  3. Y30DT again
    By Celes in forum Engine & Drivetrain
    Last Post: 7th May 2009, 14:22
  4. y30dt engine
    Last Post: 10th November 2008, 16:53
