Thread: Problem with electric windows after stereo replacement
    Apr 2012
    Edgware
    Question Problem with electric windows after stereo replacement
    Hi,
    Just had a JVC double din head unit installed in my 2008 Vectra SRi, full adaptor kit to allow the steering wheel controls to work. After the install, the electric front windows are not fully working. They go up and down OK, but the auto open/close (short click on the button and the window opens/closes all the way) doesn't work any more.
    Is there any way this could be linked to the removal of the CD30 head unit? Or is it more likely when they went fishing under the steering column for a switched live they messed something up in the wiring loom?
    Cheers,
    Martin
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Just needs the one touch resetting on each window (they probably had the battery off), hold the button up on each window until you hear the relay click, simple as that.
    Apr 2012
    Edgware
    Brilliant, thanks Ian! Something so simple
    Guess I need to let the installers know this for the future.
    Cheers,
    Martin
    Full Member Big Sig's Avatar
    They have had the battery off, for future reference, it's all in the cars manual
    Apr 2012
    Edgware
    Hum, really - need to go digging then. I checked the "Electric windows" section, thought that was enough but obviously not!
    Thanks for the hint.
    Martin
    8 Post(s)
    Quote Originally Posted by Ian-Highlander View Post
    IIRC, the correct procedure is to fully lower the windows, then hold down the open buttons a couple of seconds. Next close all the windows, then hold the closed buttons for a couple of seconds.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    That's the procedure in the book but you don't need to do it like that, the reason they give that procedure is to make sure you do the up part. Try it, take your battery off then just hold the up button til you hear the click of the relay and I guarantee you your one touch will work again
    Aug 2013
    Sarajevo
    Trim : Elegance
    Engine : 1.9 CDTI
    Thanks for the advice will try it I had the same issue after battery replacement.
  1. electric windows
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2011, 17:58
  2. Rear Electric Windows Problem
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2011, 21:21
  3. Replies: 2
    Last Post: 4th February 2011, 21:33
  4. Electric windows
    By nigec in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2009, 17:10
  5. electric windows
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 22:59
