Results 1 to 10 of 20
Thread: rear end wobble
    Dec 2010
    IRELAND
    Default rear end wobble
    I am getting a slight wobble from the back end off my vectra on uneven roads is coming from the rear passenger side . I replaced the rear anti roll bar bushes a few weeks ago and i also had the rear camber arms replaced as the bolts were seized and the tracking could not be adjusted properly i am thinking the rear trailing bushes may be the problem any ideas?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I reckon your rear shocks are needing replaced
    Regular Member borderlinechris's Avatar
    Jan 2012
    scotland/england border
    it`ll be the shocks, mines was the same esp the passenger rear, made the car feel like its turning from the rear. changed the rear control arms as well while i was there. hth!
    South east
    My vote would be for it being worn outer bushes on the rear upper control arms. Have a look at this thread for an easy way to replace them:
    http://www.vectra-c.com/forum/showthread.php?t=161771
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    TBH I would have thought a decent 4 wheel alignment place would have checked all of the bushes before doing alignment
    Sep 2009
    Glasgow
    def the shocks
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    It is the shocks, had the same problem on my Signum.
    3.2 v6 Signum and loving it
    Wear some gloves and lift each side of the rear of the car
    If there is a squeek noise, it is that specific shock absorber
    Visualy inspect each spring, they usually fail right at the bottom
    Regular Member GoldenWonder's Avatar
    Durham
    Same thing on my previous vec - wobbly back end led to back shocks being replaced (they were just showing signs of leaking) and solved the problem
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    im on the same boat
    feel a bit of twitching at the back on long bends where i go over rutts
    and my eyeballs are telling me the passenger rear has more neg camber
    wheels off defo when i finish for a few days on thursday
    think a cheap set of coilovers is what im needing as well as some polybushes and probably rose bushes for upper arma as one of the front struts are damp and im needing to give the whole suspention a good going over
  1. Balancing/Wobble/Rear Control Arms
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2011, 09:04
  2. bum wobble
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2011, 12:47
  3. Wobble between 20 and 30 mph
    By Tigger in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2011, 00:28
  4. rear wobble not shockers or trailing ams
    By sxigaspete in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 20:18
  5. rear wheel wobble
    By niicckk in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2010, 12:48
vectra c wobble
vectra c rear suspenion wobbly
vauxhall insignia rear end wobble
vauxhall vectra c bang and wobble from rear
vectra c 2005 rear wobble
vectra c rear wobble
vectra c back end wobble
vectra c rear end shakes
corsa d back wobble
wobble on vectra c rear wheel drop link
