Results 1 to 10 of 19
Thread: EGR - When do I clean it??
    Jul 2009
    Yorkshire
    Default EGR - When do I clean it??
    There are many threads on here about the EGR's clogging up or failing. What are the syptoms to look out for? And what sort of mileage do they tend to become unreliable?
    My car has done 26k miles - should I be looking to remove it and clean it yet? Cheers
    Nov 2009
    Warrington
    ive posted regarding doing this too, mines only done 30k but was gonna whip it off and have a look. will need new gaskets to re fit though i think
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    I was getting lots of lag and loss of power when pulling away from a stand still or changing up the gears. So I cleaned mine (last year) this did help. I'm getting the same problems again but this time I unplugged the EGR and gave it a test run, lag was gone and acceleration was good. But having an estate i've plugged it back in because of my DPF will get clogged up otherwise. So mine is due a clean again. Most people on here will advise a remap and get it mapped out, which is what i will do when i can save the money. If your suffering lag, loss of power then maybe worth a look.
    Nov 2009
    Warrington
    so its still a good idea to remove and inspect/clean even at 26k or in my case 30k? i had a chat a few days ago about re map and doing away with egr but cant at the min.
    Frimley
    Mileage : 140000
    If your getting the problems i had then maybe worth a look, but if the car drives fine I would leave alone for now, your best bet would be to try and get it mapped out as soon as you can.
    Regular Member Guss's Avatar
    Aug 2011
    West Malling, Kent
    can i unplug my egr valve , i have a 3.0 V6?
    Nov 2009
    Warrington
    im gonna get the money together for a re map after having a chat with another fellow member but for the time being was looking at removing egr and cleaning and maybe using 10 k boost, sorry sig 7060 for jumping in on your post.
    Jul 2009
    Yorkshire
    Quote Originally Posted by CH-VECTRA-ELITE View Post
    ...this time I unplugged the EGR and gave it a test run, lag was gone and acceleration was good...
    ...so can the EGR be removed completely (sounds too simple a solution to me), or does that cause other issues? The reason I'm asking is because I've noticed fleabay selling EGR blanking plates for the VX/Fiat engines...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Bought one of the blanking plates off of the ebay and got a tuner to remap my car and remove the EGR valve from the ECU.
    Jul 2009
    Yorkshire
    Quote Originally Posted by GazCDTI150 View Post
    Did it make a positive difference, and are there any side-effects (ie, damage to cat/DPF, emissions etc?
  1. My XP2 with a bit of a clean...
    By Mr Hyde in forum Quick Photo Album
    Last Post: 17th March 2011, 10:37
  2. clean
    By daddyjay in forum Quick Photo Album
    Last Post: 13th March 2011, 18:03
  3. Car is clean
    By VectraElite 2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2011, 23:15
  4. EGR clean up!
    By Grimo72 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 22:28
  5. My Clean Car
    By Danwells72 in forum Gallery
    Last Post: 19th December 2007, 20:13
