Thread: p0100 Fault 2.2DTI 2004
    Jan 2008
    NORTH WALES
    Smile p0100 Fault 2.2DTI 2004
    p0100 Fault on 2.2 DTI 2004 Vectra C Design
    I have replaced the MAF Sensor with new one from vauxhall.
    Cleaned Boost Sensor today. Checked all pipes for leaks.
    Still constantly obtaining the p0100 code.
    Any ideas to solve this problem ?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I don't think that's a proper code give me 2 mins
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Yep it's a maf fault mate
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    If you've replaced the MAF, it may be time to look at the wiring to see if it's secure and connected properly
    Jan 2008
    NORTH WALES
    Many thanks - Contacts to MAF seem ok - Do I need an auto Electrician or is there anything I can check myself ?
    Nov 2011
    If there's no sign of wiring damage, best thing to do is get a Tech2 session to see if the MAF is reading anything. Unfortunately it's not a multimeter job
    Jan 2008
    NORTH WALES
    Many thanks for your advice
    Jan 2008
    NORTH WALES
    MAF seems to be working fine - Limp mode (p0100 code) occurs everytime that I need to accelerate the car quickly - If I increase speed steadily everything is fine - Could the problem be the Boost pressure Sensor ?
    lincolnshire
    i'd try a new boost sensor IF all vac pipes are mint ??
    Jan 2008
    NORTH WALES
    Thanks for the advice
  1. fault p0100* but only when engine warmed up
    By mack in forum Engine & Drivetrain
    Last Post: 3rd July 2013, 08:38
  2. Fault Code P0100
    By dhwigston in forum Engine & Drivetrain
    Last Post: 1st August 2011, 06:46
  3. 2.2dti fault help required
    By sberrow in forum Engine & Drivetrain
    Last Post: 19th November 2010, 09:35
  4. Fault code P0100, AGAIN!!!
    Last Post: 1st June 2010, 14:20
  5. Fault Code P0100
    By vectra2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th May 2008, 19:08
p0100 fault code signum 2.2 dti
vectra c y22dtr p0100
opel signum 2.2 dti fault code p0100
opel vectra 2.8v6 p0100
opel vectra c 2.8v6 p0100
opel vectra c 2.2 dti p0100
Vauxhall DTC P0100-14
