Results 1 to 10 of 13
Thread: Steering intermittently heavy at low speeds
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    Default Steering intermittently heavy at low speeds
    The steering on my 03 Vectra 2.2 SRI with 43k miles has become heavy while at low speeds.
    It happens all the time now and the problem is intermittent. It feels fine then suddenly heavy and then back to fine while at low speeds.
    I notice it when I set off on a journey, once on the move I do not notice a problem.
    Any ideas?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Have you checked the fluid level for the power steering bud?
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    I've not been under it, but no evidence of leaks.
    Can you check the reservoir without major hassle?
    No low level light on the dash.
    Oct 2009
    Luton
    Is it also badly affected by camber changes in the road? Could be tie rods? Check for play at the road wheel whilst it's jacked up.
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    could be the steering rack ...
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Check levels if not it's gonna be the rack changed my Lassis on her pug hdi the other day had the same problem
    Regular Member sscully's Avatar
    Jul 2011
    WALLASEY
    Vehicle : Vectra C Facelift
    Trim : SRI
    Engine : 1.9 Diesel
    Mileage : 89000
    Same thing on mine. My mechanic told me its slight movement in the rack. He did say if it gets worse he could just change the knuckle whatever that is. Should cost 80quid instead of fitting the whole rack. Hope this helps I dont know anything more on it though
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by SYMON View Post
    Any ideas?
    Any warning lights coming up on dash - could be alternator/battery
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    Thanks for the replies.......I'll work it out.
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    Well I've been too busy to do anything about the issue, but, I have been checking the internet for research and it seems that the pump is a common faliure on the Vec C.
    The steering is getting worse too, harder and harder as the days go by.
    So I'm fairly sure its the pump.
    Going to do some checks tomorrow to make sure sufficient power is going to the pump and that all the connectors are corrosion free, etc, as low power can cause issues too.
    Will report back as and when.
  1. very heavy steering
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 19:10
  2. Replies: 23
    Last Post: 17th November 2012, 23:49
  3. Steering is a little heavy and juddery
    By freshprince in forum Suspension, Wheels & Brakes
    Last Post: 27th August 2008, 10:56
  4. Heavy Vibration at speeds over 50
    By Rodnoc in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2006, 22:21
  5. Steering heavy HELP !
    By cpt slow in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2006, 09:03
vectra c 1.9 lumpy steering
vauxhall steering heavy at low engine speed
