Thread: little help please
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Default little help please
    My cdr 2005 has decided it dosnt want to work any more so I'm getting a replacement. What do I need to do to fit it. Do I need to code it to my car or is it plug and play. Cheers guys
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Bump
    Sent from my HTC One S using Tapatalk 2
    South east
    I'm not sure, but I think it makes a difference whether the car is half or full canbus - which is yours?
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I have a cdc40 with screen divorced from a facelift if your interested mate pm me
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    To answer a few questions...
    The car with the CDR2005 is a half CAN vehicle.
    The CDC40 in the last post is a full CAN set-up.
    If you are fitting the head-unit and display from the same vehicle, then they are usually already paired.
    Half-CAN radios will need the code keying in every time you cut the battery power... so this includes first installation.
    Full CAN radios including the CDC40, Cd30 and CD70 are pre programmed (paired together),and do not require the code keying in if the battery power is cut.
    Hmmm - it is possible to convert from half to full CAN audio set-up, however it will require some wire swapping in the display (assuming you already have the 32 pin display plug...
    if not, you will first need to do the Bigmac How 2 Convert TID to GID conversion.
    Then for the head-unit, you would need to fit a few converters.
    Iso2car or SOT122S conversion lead for the head-unit itself - convert 36 pin ISO to 40 pin Quadlock.
    Aerial converter plug to convert from ISO / Din to Fakra plug
    Then transpose two CAN wires, to link between head-unit and display plug.
    To be honest, if you are converting from CDR2005, I would fit an aftermarket head-unit, such as Alpine etc... better radio for similar / less money than a Vauxhall unit.
    I am sure there is a How 2 for fixing the CDR2005.. depending upon what iswrong with yours.
    Nov 2009
    N/A
    Quote Originally Posted by Robsey View Post
    Not necessarily, Mine is half can, and I have never had to enter the code, despite having disconnected the battery dozens of times
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by mungo1985 View Post
    Ahh - Do I assume you have a NCDC2013, NCDC 2015, NCDR 2011 ?
    These are hybrid units with KWP diagnostics (Pin 12), but have mid speed CAN link between head-unit and display.
    Saying that, I don't know about the half-CAN vectra C units, but I remember that it was possible to turn off the security code request function on early Vauxhall radios.
    Nov 2009
    N/A
    nope cdr 2005 just like the op, guess the code function could have been turned off
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    So if I buy a like for like ( cdr2005 ) all I need is the radio code and it will work?
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yup -should do.
    What is wrong with your current unit?
    Not sure if it was these that were prone to dodgey on/off buttons or something like that.
    Bit of re-soldering the contacts and bob's your uncle, and fanny's your aunt.
    If it is a dodgey CD drive, then if cleaning doesn't work, then replacement drives can be bought for them.
    The upside to these CDR2005's is that there are also a few upgrade How 2's for them..
    I am sure there is an LED colour change and an Aux-in How 2 for them.
