Results 1 to 10 of 13
Thread: Like a paddling pool in car.
    Apr 2012
    leicestershire
    Default Like a paddling pool in car.
    Hi guys wondering if anybody can help please.
    Been out in car (vec c sri 2002)this morning to find that the passenger front and rear footwells absolutly soaking wet and a puddle of water on the floor,there was no windows open,however the car has been standing on my drive since last sunday so its been standing for 5 days,there is no sign of water/wet anywhere apart from in the floor wells,so it must either be the door seals or coming up through the floor.
    please help
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Has it been raining? Check under the skuttle panel. If you open the bonnet, on the passenger side of the skuttle you will see a flappy but which you can lift. Here you will find the polin filter. if you look just below the polin filter (you don't need to remove it), there is a drain and it should be clear. I wouldn't be surprised if you find bits of rubbish or leaves blocking it. I would this is the source of the problem.
    When this drain gets blocked water backs up under the skuttle and spills over through the polin filter and down through the glove box giving you wet footwells.
    Apr 2012
    leicestershire
    yes its been p*****g down most of this week.
    if its wet will i need a new pollen filter?
    Apr 2012
    leicestershire
    just been out and yes it must have had about an inch of water in there and the drain was blocked with leaves,have left heater on to dry it hopefully will be it as priced the door seals up and they are over 120 quid.for the front and rear.
    Regular Member KyleSxi's Avatar
    Sep 2011
    Runcorn, Cheshire
    Put money on it beein scuttle drain being blocked. Heres Robsey's how to m8 http://www.vectra-c.com/forum/showthread.php?t=108399
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The door seals won't be the problem so it's £120 you shouldn't be spending.
    Apr 2012
    leicestershire
    thanks guys what a really helpfull gang,while the cars been ticking over with heater on though the eml light has come on so plugged reader in and it comes up p1405 any ideas please?
    South east
    P1405 refers to an EGR valve problem, and won't be linked to your wet footwells. However, to answer your earlier question, yes you need a new pollen filter now, and also check that the heater fan works on all 4 speed settings, as the water that came through the pollen filter can sometimes damage a resistor and leave the fan only working on speed 4.
    Apr 2012
    leicestershire
    heater working on all 4 speeds will keep an eye on this,
    South east
    Regarding the EGR fault code, find the EGR valve on your engine and make sure you didn't accidentally knock off the electrical connector when you were checking the pollen filter.
  1. pool or snooker any 1 play it?
    By hoochydady in forum General Chat
    Last Post: 20th November 2010, 10:31
  2. Reserve your spot by the pool
    By steve1975l in forum General Chat
    Last Post: 30th July 2009, 16:05
  3. Urgent, I have a swimming pool in my car!!
    By Matt&Jemz in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2009, 20:24
  4. Pool Table For Sale
    By Leviathan in forum General items for sale
    Last Post: 22nd March 2008, 22:21
  5. Come on the POOL!!!
    By Silver V in forum General Chat
    Last Post: 2nd May 2007, 03:30
