Thread: tyre wear
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default Please can somebody help
    Hi
    my vec c sri is eating my front tyres on the insides. Its running on factory fit 19" snowies and ive had the tracking done but after 2 months the inside of both tyres have worn down badly.
    Can anybody advise what i can do? as its costing me a fortune
    cheers
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    anybody?
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    i'm not at all technical ,
    but here's my 3 pence worth .
    Balancing ,
    or maybe a bent rod that holds you wheel on at a wrong angle .
    good luck finding the solution ,
    them tyres ain't cheap .
    Feb 2012
    Oldham
    Geometry.
    Tracking is only one part of it…
    Chelmsford
    Get a Hunter alignment done...
    www.alignmycar.co.uk.
    I had mine done recently and was amazed by the kit they use... Sensors attached to all wheels and lasers pointed at the car!
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Your probably best to speak to a fitter at a good tyre place...if you know of one.
    I had a tyre that was really badly worn on the inside on our other car and the guy at my usual place said if it kept happening he could set the wheel at an angle to counteract it.
    Not sure how he was going to do it or how safe it would have been though.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    so is that website for hunter centres or just general tracking and alignment?
    cheers
    Some tyre history is required...
    When new where were the tyres fitted (rear or front)?
    Have the tyres been rotated?
    When removing the previous front tyres, was the wear pattern the same?
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    I just buy tyres as and when i need them, my rears never seam to wear down but my fronts have worn the inside edge down in about 2/3 months. There not cheap tyres either, conti sport.
    Ive never changed them around just leave them where they are fitted. With regards to tyre wear in the past its always been a bit aggressive on the inside and outside but since i had all 4 wheels checked and adjusted its just the inside edge thats wearing down rapidly
    cheers
    This then suggests incorrect camber on the front
    This may be due to worn components or incorrect parts
    It is also possible the front wheel alignment has used the wrong specifications, but I would need to see the actual worn tyres to confirm this (as the two wear patterns are quite different)
    Therefore have the entire steering and suspension fully examined
    When you next replace the tyres have a full four wheel alignment carried out, not just a front wheel alignment
    With respect to the 19" wheels
    Did the car come with these from new, or did it have 17" wheels and they were replaced?
    From memory when 19" wheels are fitted some of the front suspension components need to be replaced
  1. tyre wear
    By fjaimo10 in forum Suspension, Wheels & Brakes
    Last Post: 19th August 2011, 21:43
  2. tyre wear
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 20:08
  3. Tyre wear!!!!!
    By glenboy in forum Handling & Braking
    Last Post: 26th October 2009, 19:20
  4. Tyre wear
    By fishphone in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 19:09
  5. M.O.T And Tyre wear.
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2008, 20:44
