Thanks Thanks:  1
Page 1 of 9 123 ... LastLast
Results 1 to 10 of 89
Thread: Axle Weights - Add Yours Please
    South east
    Default Axle Weights - Add Yours Please
    Howabout compiling a list of axle weights for the different engines and bodystyles as a reference guide, so people can look it up easilly. Everyone has their own car's weights on the sticker on the door pillar, but for example if you're buying springs on ebay and the seller has mentioned just one engine that the springs are suitable for and you want to know if that engine has the same axle weights as your own, or if you want to know if springs advertised as being for a hatch will fit your saloon, etc etc.
    I'm guessing that we need each engine listed, in saloon, hatch, estate and Signum bodystyles, plus manual and auto gearbox versions. Later, when we have the info, we might be able to see that manual and auto gearbox axle weights are the same and can be combined, etc etc.
    If you don't see your combination of engine/body/gearbox listed in this thread yet, that means we need your data, so please add it.
    So, I'll start off:
    Signum, 2.0T engine, manual gearbox. Axle weights are Front: 1060 kg; Rear: 1080 kg.
    South east
    Bump!
    Jun 2011
    Herts
    Vectra c 2.0dti elite
    Front Axle: 1060kg
    Rear Axle: 980KG
    fronts are the same as the 2.0T signum...... interesting :-)
    South east
    Manual gearbox?
    Oct 2011
    Essex
    For the files:
    Quote Originally Posted by Rebellion View Post
    So, I'll start off:
    FLOB's Vectra c 2.0dti elite: Front: 1060kg; Rear: 980KG
    Andrew e Vectra Estate 150 CDTI S=Automatic/6 speed/towpack: Front: 1100 kg; Rear: 1110 kg
    Signum 3.2 V6 manual
    FRONT 1105
    REAR 1080
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Signum 2.2 direct elite auto front 1060 rear 1080
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    At just noticed mine is the exact same as the 2.0 turbo
    South east
    Rebellion - Signum, 2.0T engine, manual gearbox. Front: 1060 kg; Rear: 1080 kg.
    FLOB - Vectra 2.0DTi Elite: Front: 1060kg; Rear: 980KG
    Andrew e - Vectra Estate 150 CDTI S=Automatic/6 speed/towpack: Front: 1100 kg; Rear: 1110 kg
    Drinky - Signum 3.2 V6 manual. FRONT: 1105; REAR: 1080
    paulvectrac - Signum 2.2 Direct Elite auto. Front: 1060; Rear: 1080
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Vectra 1.9 CDTi (16v)hatch, auto, handbook kerbweight 1576kg, on the door pillar it has 1) 1090. 2) 985.
  1. Axle weights
    By pipamish in forum Handling & Braking
    Last Post: 14th February 2012, 22:36
  2. Axle weights
    By jlock in forum Handling & Braking
    Last Post: 20th July 2009, 23:38
  3. Axle Weights
    By paulhb in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2009, 20:30
  4. axle weights
    By lizard in forum Handling & Braking
    Last Post: 10th July 2008, 20:11
  5. axle weights
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2008, 19:34
vauxhall vectra estate front axle weight
vectra c weight
vectra c axle weights
