Results 1 to 10 of 15
Thread: guide on fitting springs?
    carlisle
    Default guide on fitting springs?
    hi my back springs snapped on vectra recently so i have just picked up some new lowering ones. is there a guide on how to swap over? also how easy is it or is it best left to a mechanic. im qwite good at practical stuff never done this. cheers dean
    Regular Member russ1969's Avatar
    Worthing
    Can be done on your drive not to bad to do really my 2nd go on the signum we had for a short time was done in about 1 1/2 hours in total
    http://www.vectra-c.com/forum/showth...hlight=springs
    Regular Member Mads's Avatar
    Ipswich,.UK
    Back ones are really easy to do and the front are not to bad either but you will need a tool to compress the front springs
    carlisle
    Quote Originally Posted by Mads View Post
    ar right mate, thats the i dont have, like a clamp. im debating weather to or not. im just being impatient
    lincolnshire
    can do the rears about 10 mins aside but the fronts need a spring compressor but are easy enough to get off otherwise
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Bring it to me mate I will sort it for ya
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by byers View Post
    The way to look at is - the money you save doing it yourself will easily buy you a pair of spring clamps and you will have the satisfaction of a. Having done it yourself b. Knowing that the job has been done properly and c. While doing these jobs it gives you an ideal oppurtunity to have a good look around underneath and hopefully prevent further jobs.
    Get yourself a Haynes Manual (not perfect but will give you some idea of what is involved) or use this forum to find out the finer points. Build up a collection of good quality tools and before long you will be surprising yourself what you can do and cutting the cost of running your motor. Good luck with it
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Better still u buy all the bits buddy so you have ya own stuff cone and see me and I will work with you and show you how to do it
    carlisle
    think im gonna have go. ill start with back. i take wheel doesnt need to come of for back spring change?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Yes it does mate lol so you can take the bolt out
  1. guide on fitting springs?
    By byers in forum Handling & Braking
    Last Post: 20th April 2012, 19:39
  2. Guide for fitting washer sensor?
    By lee gsi in forum Bodywork & Interior
    Last Post: 18th July 2011, 15:02
  3. When fitting new springs...
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2009, 01:27
  4. Fitting springs
    By icetrix in forum Northern Ireland (RO - Vacant)
    Last Post: 18th April 2008, 09:05
  5. CDTi 150 Caterman fitting guide?!
    By RobW in forum Diesel Engine related
    Last Post: 14th October 2007, 11:36
