Results 1 to 10 of 14
Thread: Drive belt, pulleys and tensioner replacement
    Jun 2009
    birmingham uk
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mileage : 106000
    Default Drive belt, pulleys and tensioner replacement
    After fitting a new alternator decided to replace drive belt, guide pulleys and tensioner. Got the dreaded 'chirp' and rattle. Would anyone know the torque settings for the pulley and tensioner mounting bolts? Tried searching forum and google but unable to find the settings :-( Its on an 8V 1.9 cdti 120. Any info greatfully received.
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    not normaly a torque setting for then just do it up till it dont go no more then you know its good
    but remember your screwing into alloy so dont go really over board
    Jun 2007
    Scotland
    Haynes manual states:-
    Tensioner 50Nm or 37lbf ft. Pulley 50Nm or 37lbf ft.
    I have the same irritating noise from my 8v 1.9 cdti. Has this work sorted the problem? How much were the guide pulleys?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Right Mate -
    Timing Belt Idler Pulley Bolt = 50 Nm or 37 lb/ft
    Timing Belt Tensioner Bolt = 30 Nm or 22 lb/ft
    Hope that helps.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Sorry Mate your talking about the auxillary belt - I got it in my head you meant the Timing Belt - Please ignore my above post.
    Jun 2009
    birmingham uk
    Engine : 1.9 CDTi
    Mileage : 106000
    Default Cheers everyone for the fast response :-)
    I do tend to overtighten things Lutonmatt but learnt from past experiences lol So many thanks alcutler and jimboy26 :-) Not fitted yet and the whole lot ie belt, two guide pulleys and tensioner came to £84 with delivery which seemed a good price, febi bilstein parts. From part supplier in Doncaster www.partsforallcars.com Well recommended, great service.
    South east
    Are you certain that you can get a torque wrench into position next to the tensioner though? On some vec engines you can't as there's very little space between the tensioner and the chassis.
    Jun 2009
    birmingham uk
    Engine : 1.9 CDTi
    Mileage : 106000
    Seems to be enough space with my vectra Rebellion, but will find out for sure when I get time to change the parts. I know there's room for the pulley between crank and aircon compressor and the tensioner but not looked at the upper pulley yet somewhere below the engine mount. I will be making it a days event anyway, got new thermostat to fit too lol..........Expecting grief with the egr cooler bracket! And yet another broken front spring to replace.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by no1vic View Post
    The thermostat on the 120 is a pain have a look at http://www.vectra-c.com/forum/showthread.php?t=158982
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    Just a word to all. You do not need the idler pulley between aircon an crank pulley all you do is remove it and get a new belt from a o8 vectra as the newer 1.9 do not have this pulley the bolt holes are still there but the pulley was removed by vauxhall. I did this on my 07 1.9. 120
  1. X18XER cam setting after renewing belt and vvt pulleys
    By Andy-G in forum Engine & Drivetrain
    Last Post: 14th September 2012, 00:14
  2. drive belt tensioner
    By coooky in forum Engine & Drivetrain
    Last Post: 11th April 2012, 18:19
  3. drive belt tensioner
    Last Post: 24th January 2012, 04:14
  4. Aux/Drive belt tensioner & pulley replacement
    By Marky in forum Engine & Drivetrain
    Last Post: 5th October 2010, 20:43
vauxhall vectra 1.9 cdti alternator belt diagram
replace tensioner pulley vauxhall vectra
how to remove pulley from vectra v belt
air con compressor change vectra c site:www.vectra-c.com
drive belt pulleys removal vectra c
vectra c drive belt idler pulleys replacement
vectra c drive belt diagram
fit vectra c cdti drive belt
how to reiease belt on vauxhall vectra
zafira 1.9 drive belt pulley
vectra c idler tensioner
vectra c drive belt tensioner vibration
how often should i change the drive belt tensioner on a vectra c
how long should a vectra c drive belt idler pully last
pulley rattle vauxhall zafira cdti
how to tighten timing belt tensioner pulley vectra c
replace fan belt on vauxhall vectra cdti
putting new tensioner on vauxhall cdti
can you remove bottom pulley on vectra c 1.9 drive belt
vectra c drive belt tensioner rattling
vectra rattle on pulley tensioner
how to remove pulley tensioner on vectra c
vectra cdti tensioner pulley
vauxhall vectra 1.9 cdti sri fan belt diagram
vauxhall 1.9 120 ac belt diagram
