Thread: Door Won't Unlock
    Jul 2006
    Question Door Won't Unlock
    Went out to the car this morning, zapped it with the key to unlock it, tried to open the passenger side rear door, and.....nothing
    Tried the key again, still no joy. Then I locked up, and started again.
    The door pin on that side shoots up and down several times when I try to unlock it, and finally comes to rest about halfway between the locked and unlocked positions. If I time it right, I can sometimes open the door during the process of the pin going up and down, but after that, no chance
    Any ideas, peeps?
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Sounds like a central locking control unit of some sort.....tried unlocking with a key?
    My 306 had this problem....Up down up down and then Up. I could only lock it with the key. There was control unit in the drivers door that was belly up. got it fixed under warranty.
    Mileage : 000
    I have this problem with the passenger door on the wifes Vectra, it tends to sort its self out but I have taken the door card off sprayed "wd40" on the door part,s but to be honest I don,t think it was mush help, only made the parts move easier though, there might be moisture in the electronic components I don,t know, if it is stillunder warrenty a trip to the dealer my be on the card,s
    Only a guess, but I reckon it a simple malfunction of the central locking mechanism. A trip to the dealership I'm afraid matey.
    As above I'd say as well.
    Jul 2006
    Thanks for the replies - 2 more q's
    Will it be a warranty job?
    Will they care that I've got alloy door pins?
    Feb 2006
    Wirral
    My pug was under Warranty...but so were the previos 12 faults..is 3 months!
    Quote Originally Posted by parapaul View Post
    If it's faulty then yes it will be covered under the three year warranty. and/or Network Q.
    I sincerely doubt it. That's in no way a factor that would affect the central locking, the module is miles away from the pins.
    Feb 2006
    Wirral
    If it's faulty then yes it will be covered under the three year warranty. and/or Network Q.I sincerely doubt it. That's in no way a factor that would affect the central locking, the module is miles away from the pins.
    Unless they tray and argue that the pins are sticking?
    That's probably all they could try and argue, but it'd be pretty clear if they were or weren't I'd have thought.
    Oh, just thought of a wheeze they may try if they're so inclined...."Sorry sir, those door pins are heavier than standard and they've put extra stain on the motor so it's knackered but it's your fault so we won't replace it!"
  1. Door unlock order?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 19:24
  2. Door Lock/Unlock buttons not working
    By midgster in forum Bodywork & Interior
    Last Post: 10th October 2010, 09:00
  3. Car will not unlock
    By STREET TWEAKS in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2009, 20:23
  4. phone unlock
    By Dwabo in forum The 'Off Topic' room
    Last Post: 29th July 2008, 15:48
  5. Door Lock/Unlock
    By Scoobydoobry in forum Bodywork & Interior
    Last Post: 15th February 2007, 19:22
