Results 1 to 10 of 25
Thread: seized rear calliper bleed nipple
    Jun 2006
    Kirkintilloch, Scotland
    Default seized rear calliper bleed nipple
    Having replaced brake pads & discs all round and the brake pipes I come to what is the easiest part of the job - add brake fluid and bleed out the air.
    How wrong I am! The nipple on the rear calliper is completely seized and was still the same after soaking it with release fluid overnight. Tried to free it with a metal punch and a hammer but all I have succeeded in doing is chipping off some metal.
    Can I drill it out or what?
    Please please don't tell me that I have to take the calliper off again!
    Thanks,
    Dave
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    why are you doin it that way just take the cap of the revisor and pump the pedal hard then pull the handbrake on then put the cap back on job done
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    sorry just notice you have change the pipes aswell will read more carefully lol
    Nov 2010
    East Midlands
    Trim : design
    Hi, have you rounded it off - if not get a tight fitting socket or ring spanner on it and very gently try and tap it undone - you could also try heating the alloy body of the caliper but obviously not that hot it would damage the rubber seals inside the caliper. If it is rounded off you could try a good pair of grips or as a last resort drill it and use a stud exractor to undo it - the main thing is not to damage the threads in the main body of the caliper - good luck with it
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    have used mole grips to get a nipple off when I rounded one off,
    Jun 2006
    Quote Originally Posted by skidmark1 View Post
    Tried it without success. There is now very little of the nut left!!!!
    I'm absolutely fed up and starting to think that this is just the start and that the other 3 will be the same!
    Dave
    Jun 2006
    Default Seized bleed nipple
    Quote Originally Posted by alcutler View Post
    Would you believe it, the other rear calliper bleed nipple is also seized!
    I've never yet attempted to free a bolt with heat but will give it a go. I suppose the idea is that the very slight movement produced by the expansion frees up the joint. Presumably I wait till it fully cools and contracts before attempting to turn the nipple?
    As I'm reluctant to apply heat to the alloy body of the calliper; would it work if I heated the bleed nipple itself?
    Thanks Dave
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Try to remove when hot, as said do not make too hot in case of damage to seals. You will not be able to heat just the nipple because of heat transfer, but concentrate the tip of the flame on the nipple.
    3.2 v6 Signum and loving it
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Where are you. I have just dug out my set of stud extractors.
    Jun 2006
    Quote Originally Posted by Johnsdutton View Post
    Thank you John, I'm in Lenzie, Kirkintilloch.
    If they are not slackening with the nut I doubt very much if they will move with an extractor. Has anyone experienced otherwise?
    Let me remove the 2nd calliper and try the heat treatment and see what happens.
    Thanks again for the offer.
    Dave
  1. Has anyone ever replaced a caliper bleed nipple?
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2014, 00:00
  2. Bleed nipple size
    By dilan in forum Suspension, Wheels & Brakes
    Last Post: 7th November 2012, 13:41
  3. Clutch bleed nipple
    By Imraldis in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 21:19
  4. Rear brake caliper bleed nipple
    By tony_b in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2011, 18:45
