Thread: Brakes
    Kirkcaldy
    Default Brakes
    Plan to replace the pads and discs all round a vectra 1.8 exclusiv. Is this a reasonable DIY job?
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    yes easy if youve got the tools and mechanically minded if not dont touch them let a professional do them
    Regular Member bigdave1701's Avatar
    York
    Yeah, It's a very simple job (even I can do it! lol). If you have a rake through the How To section you find threads on removing discs pads etc...
    The only thing you may struggle with is winding in the rear pistons as they're threaded and so require a special tool to turn them back into the caliper.
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Brakes are nothing to be scared of tackling.. remove cap on brake fluid resevior to ease pushing back of pistons
    Front calipers : Just take care when pushing the piston back on the caliper.. dont catch the rubber surrounding it.
    Screw holding the disc to the hub : Tap the bit into the screw to ensure its seated correctly and/or a small wire brush to clean it out to ensure good bite
    Rear caliper : The piston needs to be wound back in.. clockwise. Can be done with long nose pliers and a little pressure whilst doing it. Alternatively get a wind back tool.. either works fine imo
    Again screw holding disc to hub as before.
    Check fluid level.. top up if needed.. Replace brake fluid cap
    When all back together and car on the ground.. slowly push brake pedal to the floor.. repeat til pedal stays high
    Jun 2006
    Kirkintilloch, Scotland
    You are perhaps unaware that the site includes a extremely good "how to" section. This includes sections for front & rear discs. It also includes comments from folk who followed the "how to".
    http://www.vectra-c.com/forum/showthread.php?t=70471
    Good luck,
    Dave
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    brakes are easy mate i can do a hole car in like a hour and thats goin slow
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
