Thread: Is this normal.....???
    Regular Member Harry's Avatar
    Uxbridge, London
    Default Is this normal.....???
    Hi all,
    I've been driving my 3.0 v6 diesel around for about a week now and i noticed pretty eaerly on that when you depress the clutch just half way there is a vibration coming through on the pedal, you can't feel anything at any other time, only when you depress the clutch halfway, at this stage i doubt the clutch is even engaged. The vibration is in time with the ticking over of the engine.
    Just wondering if its normal.
    Any thoughts? The car is on a '54' plate and had only done 10k miles, just had its first service aswell, not sure if it would be checked though.
    ARE THE CLUTCHES HYDROLIC ? I CAN UNDERSTAND A CABLE CLICKING .....
    Uxbridge, London
    okay...kinda worried now.
    Big phil - it's not a clicking that is present, but when i press the clutch pedal down slightly (until there is significant resistance) at that point i can feel the vibrations of the engine running through the clutch pedal.
    it's quite difficult to explain - but seeing as nobody else is experiencing it i think i'll take it to the stealership and see what they make of it. year one warranty runs out on the 6 of this month!!!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My old Vec B used to do that. It was also diesel. I just put it down to the engine vibration at idle, (as diesels at idle can vibrate a little more than petrols) Never got any worse, or better, and I got rid of the car at 92K miles.
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    Ignore
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Thumbs up
    Quote Originally Posted by Harry View Post
    Hi all,
    Hi mate, dont take this as 100% but when I bought my CDTI SRI 150 on 55/2005, with less than 10k miles on it, I noticed the exact same thing. I took it to my VX dealer and they said that some vibration on the clutch pedal is normal as it has a Dual Mass Flywheel. But on mine at the time the judder seemed quite a lot, so mine had a new flywheel in it at the time (apparently quite a common fault). If it is a slight judder, like a minor bouning type feel, then I would say its normal as I have an SRI CDTI 120 and a 150 and they both do it and VX have told me that its normal. If its more than a minor feel, then get it cheked. Dont hold me to this thouhg, its just what I was told. Hope this helps bud. Thanks.
    hee hee this thread is 3 tears old hee hee
  1. Normal or Way Out?
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 19:22
  2. is this normal ?
    By bigbranno9 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 10:41
  3. is it normal
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 4th January 2012, 22:24
  4. Is in normal?
    By Pulja in forum Diesel Engine related
    Last Post: 28th June 2011, 20:20
  5. ...Is this Normal??
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 18:58
vectra c clutch pedal half way point judders
