Thread: warning lights
    Kirkcaldy
    Default warning lights
    My vectra shows the bulb out display on dash. Have checked everything and all is ok. Any suggestions Please.
    Regular Member coldo's Avatar
    Scotland
    O read a while ago that the system can detect a bulb which is on it's way out as there is a drop in the voltage resistance across the bulb (or somethign like that)...
    Chances are a bulb will fair soon it it's not already mate../..
    Kirkcaldy
    This has been on dash for weeks now.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Which bulb does it say is out?
    Scotland
    Im assuming its a prefaclift you have with the small display on the clocks which is showing the buld is out... In which case you just need to check all the bulbs visualy....
    West
    Have you checked the reversing lamps
    8 Post(s)
    Double check the rear bulbs.
    There are 2 tail light bulbs on each side of the car. The upper one is also the brake light. Should the upper bulb fail, the lower bulb takes over the role of tail / brake light.
    Rear light positions (from the top down)
    Indicators
    Tail & brake lights
    Tail lights (which then becomes a brake light as well should the original tail/brake light fail)
    Fog light (drivers side only - UK)
    Reverse lights.
    All bulbs are 21 watt single filament bulbs.
  1. ABS and ESP warning lights
    By ChristopheCDTI in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2011, 17:13
  2. warning lights
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st January 2011, 17:09
  3. warning lights
    By jules in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 22:09
  4. warning lights
    By lee_car in forum Vectra C / Signum Troubleshooting
    Last Post: 30th October 2008, 14:01
  5. warning lights
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2008, 21:20
