Results 1 to 10 of 15
Thread: Signum v6 cdti 3l auto
    Mar 2012
    alton
    Default Signum v6 cdti 3l auto
    Hi there
    Was wondering if anyone can help me I have the car above and have been driving it for a few months now I am finding when going speeds of 50 to 60 it can't seem to make its mind up which gear tobe in 5 or 6 any else find this it's my first auto so not sure if it's normal! thanks all who reply.
    Barrow In Furness, Cumbria
    It will depend on how much throttle you're giving it. If you're pushing down on the throttle enough to think you're trying to accelerate (or going uphill) then it will drop down to give you more power.
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    as above ........it is a fine art of balancing the right revs ..
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    . It does irritate me a little that I can force the upchange as early as I would on a manual.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yep mine also chanegs its mind alot but after a year i have mastered it
    Regular Member ben_3.0v6's Avatar
    Apr 2011
    EMEC #3
    Mine does this and yeah waiting untill 60 to have to change to 6th is rather annoying but after a year of it I've about mastered it, and can see why when u do finally get into 6th as it drops to around 1000rpm, so at 50mph it would only need around 500rpm.
    lincolnshire
    thats why i like the auto box in my merc ! i can dab the gearstick to hold a gear so it does hunt or drop into 5th at 25 miles an hour , odd that VX never fitted a tip box on at least the 3.0 deisel
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    You can on my Vec auto push it to the left and manually select the gear it won't go up unless you make it but it will drop down as you slow down in case you forget
    Apr 2011
    EMEC #3
    Yeah the auto does have a tip-tronic gearbox but the auto mode will hunt if you put to many revs on at the bottom end of 6th gear range.
    Oct 2011
    Essex
    Mine only likes 6th above 70/80 really, in an average speed camera'd 50 motorway it sits in 4th or 5th. Knowing a friend who sub-contracts in and out GM, I queried this. His view? Too high a gear and the diesel is actually LESS economical, you get the @chugging@ effect, which in turn clogs everything to bits.
    Now I can understand this, as the generators (during my days as a generator hire fitter) which ran off load all the time were caked to hell in carbon - have you ever set an exhaust on fire during a load test - so I guess the softwear for the ECU decide the raised rev's (about 200 on mine) are preferential to a carbon'd up engine.
    My BMW had a 5 speed auto which always started in 2nd funnily enough!
  1. Signum cdti 150 auto
    By Dunc in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 22nd January 2009, 20:10
  2. Signum 3.0 CDTi V6 Auto MPG Question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2008, 22:38
  3. 3.0 CDTi Auto Signum Elite
    By Adamdavi3s in forum Cars for sale
    Last Post: 26th November 2007, 10:16
